Originally Posted by BDP24
Thanks Don. Actually, my pre-amp has a fairly low output impedance (under 200 ohms), and my amps a pretty high input of 100k ohms. Does the 100k input impedance of the power amps make it a problem to implement a passive parts filter on the input jacks? I'm not an electrical engineer, but I think it takes only a resistor and a capacitor at the amp's input to create a 6db/octave rolloff at 80 Hz. The stereo power amp I did it to has an input impedance of 50k ohms, and it was very simple. I would like the sub to have L & R stereo XLR outputs with a HPF, to both get a 12/db roll off to my amps and to avoid the extra jacks and interconnects that an outboard x/over would mandate. I can get the 6db roll off with passive parts on the power amp's input jacks, but I can't use the passive x/over (6db/octave, with control knobs) that I already have---it has unbalanced RCA jacks. I can accept an unfiltered signal on the subs output jacks, but I absolutely MUST have L & R balanced XLR input and output jacks on the sub. I use long interconnects (with XLR's) between the fully balanced output of my pre-amp and the fully balanced input of my power amps, which, as I said, are directly behind my speakers. Is there a version of the 370w (or 600w) amp that has L & R balanced XLR inputs and outputs? The A370XLR doesn't, nor does the A370XLR2. Is there one that does AND has PEQ? Is there anywhere I can see all of the different configurations of the control panel that Rythmik offers? I have seen the layout of XLR2 (Brian provided it on a previous posting), and if I were to get two Rythmik subs with the A370XLR2 (or A600XLR2) amp, I would have everything I want and need (it has one channel of HPF'ed outputs on XLR's, and two on RCA's). Plus stereo subs! Hey, with the 10% discount for multiple purchases, a pair would only be a couple of hundred bucks more than the SVS SB13-Plus (if, when it is available again at the end of Summer 2012, it is back to it's original price of $1599). And, if all of you are to be believed (smiley face!), with better sound quality for music reproduction. Something to think about. Thanks again---Eric.
I had a little trouble following all this... There are pictures of the various amplifiers on the Rythmik site, and of course Brian can provide more insight.
Using a passive filter you would like very low driving impedance and very high load impedance, which you have. Yes, a simple first-order RC filter provides 6 dB/octave slope, but many passive filters use an LC circuit to get 12 dB/octave with just two components (the inductor allows you to get an extra 6 dB/octave). There are probably websites that describe the filter, or you could buy one. Most balanced passive filters add an extra component so (+) and (-) signal see the same impedance to each other and to ground.
A typical balanced LC HPF would put capacitors in series with each signal line (+ and -) and an inductor across the +/- signal lines after the capacitors. The inductor is a low impedance ("short") at low frequencies, and the capacitors high-impedance ("open") at LF, so the combination of shunt L and series C provides a second-order (12 dB/octave) HPF.
You could use transformers to convert your single-ended passive design to balanced, but the same effort should get you a new balanced design.
HTH - Don
