I have the subwoofer firing straight. I have tested it with 45 degree angle and it created bigger dips everywhere. I have placed the single subwoofer between the two blue dots on the left, where it also created more serious dips but shifted the 32Hz null to other frequency. I'll try with the suggested placement (between the 2 blue dots on the right) once I got the second FV15HP with me. But is it OK to have 2 subwoofers placed at different distances from the main listening position? My AVR only has Audyssey MultEQ XT, which it cannot time-align 2 subwoofers separately..Originally Posted by LarryU
Hi Skylinestar,
The null at 32Hz does look like a room null and I’m sure you were aware of that, and you know that the corner is the worst place to put a sub. I would imagine you have the sub facing out at a 45 degree angle, you could try turning it to fire down the front or side wall and it may help but I don’t think it will. I think this is from sound bouncing off the back wall so you need to move the sub closer to the back wall to move the null out of the listening area. If you put a second sub where you have the star I don’t think it will help because it’s still the same distance from the back wall. If you could put the second sub between S2 and B3 around where the blue dot is that should eliminate the null at 32Hz. Try putting your sub there temporarily and take a reading to see if the null at 32Hz is gone if so then a second sub should solve your problem. Also try using either 1/6th or 1/12th smoothing on your graph, it will get rid of all the sharp rises and dips so you can see really were your problems are, you can’t hear those sharp fluctuations and it makes the graph closer to what you really hear. These settings are not from me but from Brucek in one of his tutorials on REW on HTS.com. You might also look at some form of EQ to dial in a house curve, read some of the tutorials on REW for more information on this. Just my 2C hope it was helpful.
Larry
Hi Skylinestar,
Larry
But here is the Cliff notes for the entire interview:
