Originally Posted by sydneyaudio
Hi guys, i have a (confusing) question regarding my F15HP.
If I have my AVR connected via LFE in, and a preamp connected via Line in - which controls the sub if both are on and active?
Is there any risk to the sub amp if there is an active input on both the LFE in and the Line in?.
For watching movies I have the FL and FR channels going via HT bypass on the preamp, with the AVR connected directly to the sub LFE in.
When listening to music one of the the preamp outs is connected to the sub line in - so the sub is active for music (I have a separate high pass control on my active speakers and use the low pass on the sub).
Unfortunately, even in HT bypass mode, both preouts on the preamp are active. Hence, when watching movies, the AVR would be sending a signal via LFE in, and the preamp a signal via line in.
Thanks in advance
Thanks in advance
There are two options in terms of how to set up in HT. The 2ch mode is same (front speakers full range, sub is used to supplement the bottom, and therefore, customers will use 50hz/24 setting to dial in the 2ch mode):
First option is to run the front speakers full range in HT. In this case, the FR/FL have the full range signal, just like the 2ch mode. LFE signal will go out from SUB channel of AVR.
Second option is to set the front speakers to small, and set tthe crossover point as high as possible (90hz) and set the SUB channel 3db hotter (actually in HT mode, most people do enjoy 3db to 6db hotter sub channel). With clean sounding subs, it can sound better that way. By doing this, we limit the the signals going to FR/FL which then goes through the line-in inputs leak into the subwoofers.
BTW, via PM I know you have a separate highpass control on your active speakers. In this case, your natural choice will be optoin 1.
Edited by Rythmik - 11/8/12 at 8:07am
» Get the latest news and updates at the Rythmik sponsor page.
