Featured Stories
Topics Discussed
Related Forum Threads
- How to connect rhythmic subwoofer F15 to Marantz AVR? Last post on 4/20/13 at 3:39pm in Subwoofers, Bass, and Transducers
Official Rythmik Audio Subwoofer thread - Page 266
AVS Top Picks
- XStanleyX
- Trader Feedback: 0
- offline
- 1,921 Posts. Joined 11/2004
- Thumbs Up: 67
- Select All Posts By This User
- Smigro
- offline
- 1,133 Posts. Joined 2/2009
- Thumbs Up: 11
I do not have my own calibration equipment so I have to rely on Audysey. Even I were to try an adjust it manually I would not even know what to be listening for.
- woody777
- offline
- 588 Posts. Joined 12/2007
- Thumbs Up: 10
Hmmm, I may have misinterpreted "I ran Audessey MultEQ. It set my front speakers to large and turned on a setting called double bass. I crossed them over at 80 instead. I tweaked the levels just slightly with a db meter (Audessey got pretty close) and ran the sub about 3 db hotter than the rest."
Definitely respond to Brian / Rythmik reply. They are smarter than me. What are your mains and what is your AVR? I stand by the Klipsh doesn't hold a candle to your sub though.
I didn't explain it very well -- but basically Audyssey said one thing, but I changed it to what I know to be right. Even Audyssey advices to change the speakers from large to small if you run a sub and Audyssey doesn't set a crossover. Either way, I certainly believe you when you say that the Rythmik should outperform the Klipsh -- that's why I bought it
I, also, have experienced the "lack of output" when you first fire up the sub. After talking to Brian, I am convinced it was just due to the sub not being broken in yet, and the spider/surround needing some exercise. After a day or two, the sub started sounding much better!
I understand... but something is just off. Running the sub at moderate volume levels shouldn't result in flapping/farting sounds from the drivers. There was no sound on major bass hits in music and very little sound on movie effects. It was almost just a background bass drone. I had to put my ear to the drivers at time to make sure it was still on.
I've had some difficulty with Audessey in the past. I ran Audessey, but then calibrated levels by hand with a db meter. I ran the sub with Audessey on and off. It sounded better on, but not by much.
Brian gave me a call today -- just from this thread and a PM (from him). I didn't have to "officially" even contact Rythmik. Despite issues with my sub, customer service so far has been top notch and I'm sure the issue will be resolved.
- Cowboys
- offline
- 325 Posts. Joined 6/2012
- Thumbs Up: 15
I am lucky as my FV15hp worked out of the box and I am still amazed with how it delivers. Honestly I got scared listenning close to -5db with sub 3db hot
- K5/SS
- offline
- 172 Posts. Joined 3/2011
- Thumbs Up: 10
- dstew100
- offline
- 929 Posts. Joined 11/2005
- Thumbs Up: 21
- DonH50
- offline
- 4,413 Posts. Joined 2/2010
- Thumbs Up: 46
- woody777
- offline
- Thumbs Up: 10
No hum or buzz of any kind. I haven't tried another cable -- I'll do that tonight. I'm using a brand new cable (not that that necessarily means it can't be at fault) from Monoprice.
- Rythmik
- offline
- 1,558 Posts. Joined 8/2005
- Thumbs Up: 21
I know this may be a Stupid question but I have a question regarding fv15hp mcaac sets the db to -0.5 and the volume on the sub is 3 clicks above 80 I run my sub 6 db hot which is great for movies but not so much for music I listen to a lot of rap is it safe to turn the volume on the sub to 3 a clock or is that dangerous basically I would like to know how loud I can play the sub at?
It is safe if your front speakers are very efficien, or you really like special effect. For music, too much bass may not be a good thing as you have notice. High damping is good for music as it has less ringing. But low damping gives you more full body rumble effect (that does not come and go as fast).
- pyronious
- offline
- 13 Posts. Joined 1/2003
- Thumbs Up: 10
For rubber feet, I saw these "bench cookies" mentioned and they seem affordable but their vibration isolation properties are unknown as they are not designed for this purpose.
For a platform, the most common recommendation is the Auralex subdude. However, the base of the F15 is 19"x20" and the Subdude is 15"x15". Is it OK (or perhaps even beneficial) to have the sub hang off the edge of the isolation platform, or should I upgrade to the Great Gramma, which is 19"x30"?
Lastly I see a lot of people just using speaker spikes resting on a coin (like a quarter). Thoughts?
- XStanleyX
- offline
- Thumbs Up: 67
Hey folks, I'd like to get your opinion on placing a Rythmik F15HP on a hardwood floor. I've heard several people recommend some kind of vibration isolation to decouple the subwoofer from the floor. Of those, there's the "rubber feet" camp, the "isolater pad" camp, and the "spikes on coins" camp. Any thoughts on one over the other?
This is what Bill Fitzmaurice has recommended: http://www.amazon.com/Genuine-Joe-Anti-Fatigue-Beveled-3-Feet/dp/B000EFK9KM/ref=sr_1_12?s=home-garden&ie=UTF8&qid=1358282258&sr=1-12&keywords=comfort+mats
Inexpensive and effective.
- DonH50
- offline
- Thumbs Up: 46
- XStanleyX
- offline
- Thumbs Up: 67
- KMFDMvsEnya
- offline
- 1,093 Posts. Joined 6/2007
- Thumbs Up: 15
Audioholics has an article that discusses this topic of 'vibration isolators' and the overall verdict is they are unnecessary and in fact can increase vibrations. Spikes can be useful for thick carpets but on hardwood not helpful.
http://www.audioholics.com/education/loudspeaker-basics/speaker-spikes-and-cones-2013-what2019s-the-point
Best regards,
KvE
- K5/SS
- offline
- Thumbs Up: 10
- sportwagon
- offline
- 42 Posts. Joined 11/2009
- Thumbs Up: 11
I have the Rockler version of the bench cookies, they are a great addition to any woodshop, but I am not sure they would be very effective under a large subwoofer. Basically that center part of the cookie is just a solid piece of plastic, with the 1/4-3/8" of rubber padding on each side (this was found out by an unintentional dissection of one of my cookies by my router :-) . This makes them great for raising up items on the work bench (good grip, good stability), and the do help to isolate some vibrations, but given the thickness of the rubber, mostly in the high frequency range I would imagine (think router). I had looked briefly at the auralex a while ago, and from what I remember, there is much thicker isolation "foam" that is engineered for the bass frequency range. When I finally get around to building my own Rythmik subwoofer, I will probably look at something like that myself.
- XStanleyX
- offline
- Thumbs Up: 67
Awesome. An Emotiva is next on my list. I was going to get a XPA-2 first while they were on sale but they were out of stock at the time so I pulled the trigger on the sub. They still don't have them in stock. Now I'll have to pay full price unless I wait for another sale but who knows when that will be. Oh well.
Congrats on the amp!
- Eldiablos
- offline
- 442 Posts. Joined 8/2010
- Thumbs Up: 11
I have wood floors also. I bought the Auralex Great Gramma for my fv15hp and it works really well. The sub fits perfectly on it.
- Bill Fitzmaurice
- online
- 5,484 Posts. Joined 11/2009
- Thumbs Up: 174
The Isolation Claim: ‘Its purpose is to prevent sound from transmitting through your subwoofer to surrounding surfaces. Subwoofers create big vibrations (low frequencies) that you can feel in the floor and in objects placed nearby. When the source of the vibrations is coupled directly to the floor it causes these objects to vibrate or resonate…’
The Truth: The source of these vibrations is the movement of the driver cone. The claim would only be true if you coupled the driver cone to the floor. If the cabinet panels vibrate enough to cause the floor to vibrate the speaker is defective.
The Decoupling Claim: ‘Isolators for your speakers…will decouple your speakers from the surface they rest upon, resulting in a more pure, accurate tone. Low frequencies will be projected and will no longer lack the definition you desire. Mid and high frequencies will be crisp and intelligible. Rattles and resonances will be a thing of the past.’
The Spike Claim: ‘By rigidly coupling a loudspeaker enclosure to a floor by means of a spiking system, it is possible to dramatically improve clarity, stereo imaging and bass response. This is very apparent with subwoofer systems.’
The Quandary: These sources claim the same benefits from coupling and from decoupling. Who’s telling the truth?
The Truth: Both are lying. Isolation and coupling makes no difference. To test this I measured the response of my THT and my David with the test mic in the room, in the next room, and in the room below, with the cabinet sitting on the carpeted floor, on four inches of high density acoustic foam, on rubber feet and on spikes. I’d post the measured results for each set of comparisons, but there would be no point. In each case the measured responses of the four options were identical.
Note that this was on a carpeted floor. There may be some slight benefits to isolation devices or rubber feet on a bare floor, or on a bare shelf or stand. But you never want a bare floor, it’s an acoustical nightmare. If you only have area rugs in your listening room stick a piece of felt carpet padding, a carpet scrap or rubber feet under your speaker. If you're using bookshelves on a bare shelf or stand small rubber feet or felt pads are all you need to prevent spurious vibrations.
The Endorser Claim: ‘I tried them and they work, I know what I’m hearing!’
The Truth: The first thing you learn in an acoustical engineering course is that you don’t know what you’re hearing. If you did you’d be able to listen to a speaker, take pencil and graph paper in hand, and draw a frequency response chart, THD chart and waterfall plot, all with 1/24 octave resolution and 1/10dB accuracy. Our ears just aren’t that good, not by a very wide margin. But our imagination works very well, and that clouds our audio judgment, leading to placebo effect. In short, if you think something will make a difference in the sound, it will.
For an in depth examination of why we really don’t know what we’re hearing check out this video:
http://www.youtube.com/watch?v=BYTlN6wjcvQ
- Skerlnik
- offline
- 130 Posts. Joined 5/2012
- Thumbs Up: 12
It's all you need, assuming you need anything. Next to high priced cables and power conditioners isolation pads and spikes are the biggest scams in audio. The following quoted claims are taken straight from the websites of manufacturers of these devices:
+1 Great post!
- DonH50
- offline
- Thumbs Up: 46
The only time I have measured the impact of feet on speakers was ages ago at a store I worked at in the 1980's. The step/impulse response was better (on a 'scope, using a measurement microphone and preamp) with spikes through the carpet to the concrete floor beneath than with the speakers (Magnepan and B&W IIRC) just sitting on the carpet. We convinced ourselves we could hear the difference; however, the difference was not heard in a few blind and DBT runs (no better than 50-50 right answers among the group we tried). There was a slight bias towards positive with the Magnepans but I was never sure it really mattered in the real world.
- K5/SS
- offline
- Thumbs Up: 10
- Bill Fitzmaurice
- online
- Thumbs Up: 174
- mikepos
- offline
- 119 Posts. Joined 12/2005
- Thumbs Up: 10
For single sub I'm drawn to the FV15HP but am concerned I'll still need 2 to even out the bass and adding a second is more than I want to pay. So I'm considering trying the F15 first then adding a second if needed but I'm concerned about volume for those (would probably go middle of front and back walls if I got two). My room is dedicated and sub size is not important. I hope the F15 or FV15HP will help me even out bass with the PEQ and would like to start with one unit.
I live in Canada near border and would ship to Maine but I don't want to be hit with shipping for the 30 day trial... can I expect to be happy and have headroom for the F15 (370PEQ)?
Also, is there any sound or performance difference if saving $100 with the 550PEQ3 on the FV15HP? And if I got this now and added a 2nd FV15HP with the 600PEQ3 (say no 550 left) would there be any issue matching them? I've seen a few amp issues posted lately, are these the 550 or 600W amps - please post if you're one of those with amp issues.
Lastly, can anyone compare the Hsu vtf3mk2 (same as current vtf2 but with 50W more amp) compared with the F15 370PEQ3 for SPL?
thanks.
- Rythmik
- offline
- Thumbs Up: 21
And from the moisture released from the concrete. I had a plastic mat under my chair over wood floor then over concrete. I know people say the concrete will release moisture. But what is the proof? After 5 years of not ever moving the plastic mat, my hard floor turn black and it is sticky when I for the first time moved the mat. The wood is not destroyed, but clearly discolored.
- Kamikaze13
- Dragons Lair Theater
- offline
- 172 Posts. Joined 8/2007
- Thumbs Up: 11
- qguy
- offline
- 464 Posts. Joined 12/2008
- Thumbs Up: 18
I'm undecided between subs and number of subs. I play moslty home theater but also music and am fussy on music reproduction. My room is 14 x 18 x 8 ft and my mains are PSB stratus gold fed by oppo95 direct to Bryston 3BST (very SPL capable combo), with Lexicon (bryston) 5ch for surround channels, no pre/pro. I play very loud music and movies and need good output. My current sub is corner loaded Hsu vtf-3mk2 and it's output hasn't failed but I have turned down the volume in load bass heavy scenes to be safe, I feel I'm pushing the spl limit. My bass response is quite uneven and I'm considering 2 subs to help fill nulls (I sit near one - length wise in room mains are 3' off front wall and I sit about 1/3 off rear wall, gives best music this way). I find the Hsu a bit boomy currently but much trial hasn;t found an even spot for it including moving seat a bit.
thanks.
- pyronious
- offline
- Thumbs Up: 10
Thank you for the thoughtful response. I recently went to a local audio society meeting and the theme of the meeting was "tweaks". Lots of different devices were demoed and I am convinced they were all snake oil. I'll probably just use the rubber feet that come with the subwoofer. Thanks!
- dominguez1
- online
- 871 Posts. Joined 12/2008
- Thumbs Up: 14
Interesting. This is the first rebuttal I've heard regarding the benefit of isolation pads.
Cabinet panels do vibrate...I guess it's a question of how much they impact the floor.
For example: If you put 4 'feet' on the top of your subwoofer, and then placed a large container of water on top of those feet and then played bass heavy content, you will get movement of the water. Now if you put an isolation pad on top of the feet, and then the large container on top of the isolation pad, you should get less movement of the water, correct? The isolation pad will reduce vibration to the container of water because of the increased surface area and vibration absorbing material of the isolation pad?
- Official Rythmik Audio Subwoofer thread
Recent Discussions
- › The Official Xbox One thread... 5 seconds ago
- › Calling all Polkies:Official Polk thread 2 minutes ago
- › Primus Cheese in 5.1! 2 minutes ago
- › Samsung UNXXF6400 Thread 2 minutes ago
- › Sony MDR-DS7500 - World's first HDMI lossless 7.1 surround... 2 minutes ago
- › Xbox One Shared Game Library 2 minutes ago
- › 1 inch CD Comparison (SEOS18) 3 minutes ago
- › *** The Official APERION Thread *** 4 minutes ago
- › Official 2013 LG xxLA7400 Owner's Thread. 4 minutes ago
- › Need some help please 4 minutes ago
Recent Reviews
- › Sony BDP-S5100 3D Blu-ray Disc Player with Wi-Fi by imagic
- › Yamaha Aventage Blu-ray Player Black - BD-A1020 by foursticks
- › Panasonic DMP-MST60 Smart Network Media Streaming Player with... by amesdp
- › Sonax E-0062-BF Fiji 60-Inch TV Component Bench, Ravenwood Black by DDT0C
- › OPPO BDP-93 Blu-ray Player by KingLeerUK
- › Sony Blu-ray Disc Player - BDP-S790 by wisccheese
- › Samsung BD-C6500 1080p Blu-ray Disc Player by NeonSignedOff
- › Panasonic DMP-BDT220 Integrated Wi-Fi 3D Blu-ray DVD Player by bettzysdaddy
- › Panasonic DMP-BD65 Blu-Ray Disc Player (Black) by dasher123
- › Where's The Wires, LLC Streaming Media/Soundbar Power tool by wheresthewires
New Articles
- › Why is LED light known as long life by Davidsmith001
- › Blu Ray Player Review Contest by Mike Lang
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
