Originally Posted by
BeeMan458
Gee. Funny. That's how things are at our place. A few days with REW up and running with a break of about two weeks or so and then REW up and running again. Like you, I'm currently in the REW on the shelf phase of our relationship. Next week I'll have cables all over the place with REW up and running again.
Concerning REW set up permissible length of time and treatments...
I present a well thought out, rationale position based on sound scientific principles for each of these issues. I define and clearly present the benefits that will be achieved, yet somehow I don't even get close to success against an irrational and frankly unreasonable position
BeeMan458
Good to read you're a REW fan. Room analyzing programs are a type of sonic religion with me: "I was blind and now I can see." "Everybody needs to convert."
Totally agree, I can't imagine not being able to measure the impact a change to my system actually made (now that I do measure). When I look back at me throwing hundreds and sometimes thousands at upgrades blindly it is just madness. REW rules. Fortunately I never bought into the cable craze that my dealer pushed hard. Isn't it awesome how today we can actually back up "I don't believe you" with real measurements we run on our own system and not just some claim that contradicts some other claim?
BeeMan458
You mentioned a minidsp. Is one better using a minidsp vs the Anti-Mode we have? I'm all for what works the best to tame those peaks. Currently I tune with REW and then run Anti-Mode and XT but I want better and I feel I can only get better with better. Don't got no XT32 and to get XT32, I'd have to replace a recently upgraded AVR.
I don't think I'm strong enough with this stuff yet to say anything definitive but here are some thoughts which probably aren't anything you don't already know. Also I don't have direct experience with antimode, I've just read up on what it does and read many positive comments on it. I think since you have the antimode the difference XT32 would make, if any, is minimal. The XT32 advantage over XT is higher resolution filters on the sub, and you're already getting quality sub EQ.
Now on the minidsp vs antimode and audyssey technologies. Antimode and Audyssey are super automated and very easy to use. That's nice but unless you have the audyssey pro kit you really can't play with custom curves and manual EQ. That being said minidsp can do some really really complex things, beyond what I totally understand yet, and you can do totally manual EQ with it. It is an amazing little gadget with tons of kewl stuff (low pass, high pass, delays, crossovers, splitters/duplicators/multiplexers, more complex filters, boosters, attenuators, filter bandwidth controls, etc...). It's super Kewl, can be hard, can be awesome if done right, easy to screw up and do bad things, you know. It should be noted though that REW can suggest EQ filters for you, and with a minidsp REW can auto-configure the minidsp to apply them. How that compares to antimode and audyssey, ????????????????
The kewl thing is with REW we can measure what all these tools are doing. Not only in the final speaker output but you can run a loop through any of these devices and measure directly what it is doing to FR. I think we should be careful layering EQ on top of EQ, but with measuring, some trial and error, and patience we can get some great results.
What do you think?
