Originally Posted by
matted
how comparable are the video solutions employed in the non-v D2 versus the MX series?
D2 vs D2v video are not hugely different except that non-v is not a candidate for 3D hardware upgrade.
As for VXP vs Torino, there isn't much to compare. The latter does 1080p upconversion and that's about it (a decent job with the usual test discs) whereas VXP has deinterlacing to rival anything and a setup menu all to itself.
Speaking of, the cropping options in said menu are my favourite thing about it so a few words on that... Need a special setting for a misaligned TV channel (like practically all SD on Rogers), or one that underscans like TCM-HD when playing non-4:3, or for Criterion DVD which does the opposite? Need only two lines of garbage removed from the top edge? You can crop and center one line at a time to your heart's desire and store various settings in input memory layers. There's also gamma correction for when the display doesn't have it and could use it.
On the flip side, something that MRX has over AVM/D is that it automatically switches output to 1080p24 if the TV accepts it and source is 1080p24. Known recently revealed issue to go with it... if MRX is in Through mode it doesn't play nice with 24p-enabled Oppo BDP-83 with 24p. Easy fix with nothing to lose - don't use Through mode in MRX, use Auto or 1080p instead. Output resolution can be changed on the fly, but not while it's trying to sync. Software engineers are looking into it. 1080p plus Through does work with Anthem BLX 200 though. All a mystery for now.
