Originally Posted by Nick @ Anthem
On the flip side, something that MRX has over AVM/D is that it automatically switches output to 1080p24 if the TV accepts it and source is 1080p24. Known recently revealed issue to go with it... if MRX is in Through mode it doesn't play nice with 24p-enabled Oppo BDP-83 with 24p. Easy fix with nothing to lose - don't use Through mode in MRX, use Auto or 1080p instead. Output resolution can be changed on the fly, but not while it's trying to sync. Software engineers are looking into it. 1080p plus Through does work with Anthem BLX 200 though. All a mystery for now.
I had some problems with a Panasonic DMP-BD80 sync'ing with my Epson HC6100 PJ when running a BD title at 1080p/24. Think I had the hdmi set to through. Will check when I get home Thursday night. It did eventually settle in and display, but it took almost 2 minutes to display the picture with a bunch of flashing screens and sometimes full screen snow.
If you own good loudspeakers, you should focus on correcting the low frequency acoustical interactions between the loudspeaker and room.
