AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › Connecting PC to projector using DVI-Component cable
post #1 of 5
Hi
I have a HP media center slimline PC 3500t , which I want to connect to both projector and TV. My PC has both HDMI and DVI port and am using HDMI to connect to the PC which is working fine. I also have a component wire running from inside the wall to the projector which I want to use to connect the projector and PC.
I tried using a DVI to component cable and connected it to my projector but having some issues with it. I only able to get a resolution of 640x480 which doesn't work for me. If I connect my DVI directly to TV , I am able to get higher resolutions too.
How can I get a higher resolution using DVI/component cable ? Since my component cable is already running inside the wall to the projector , don't want to use a new cable.
Anurag
post #2 of 5
http://www.monoprice.com/products/su...09&cp_id=10419
Have you consider an hdmi switcher or splitter?
post #3 of 5
I already have a component cable running up till the projector so would want to use that if possible.
post #4 of 5
Did you tried setting up your media card output resolution/type etc. With component you should get 720p.
post #5 of 5
Actually that's what I want to do but can't seem to get it working
