Originally Posted by Eiredale
I'm steaming off a 1Gb lan, no transcoding, direct to OPPO. HD files play fine over the network on any of my PCs w/ MPC, VLC, JRiver (DirectShow), etc. so it is not a LAN issue. I choose the mkv container specifically as a file type that OPPO handles (rather than fight the m2ts battle). As I have mentioned, DVD rips are fine only bluray fails. As file size in this case is directly related to bit rate, I chose that comparison as others are trying to relate 1080P torrent or equivalent to bluray. I and others have experienced the same problem in that the OPPO will not handle high bitrate bluray files. I have friends that are doing bluray with WD TV Live and Popcorn C-200. It IS the player.
Have you tried a small sample from a USB device? That might distinguish DLNA and network issues from codec issues
-Bill
as the pitch has gone way up (although the speed appears to be correct). So, getting closer but not quite there!
