I emailed OPPO and they responded that currently the 83 does not support HD audio in a MKV container. They are looking into possible support in the future. They did say that the DLNA might support HD audio in original AVCHD format IF they get the ethernet bitrate problem resolved. Apparently HD audio is supported over USB if in AVCHD. I am working on setting up a larger Fat32 USB drive to test AVCHD format on a full Blu-ray rip. You can divide a full movie into 4GB chunks in that structure. I can get MKV files (from a full rip split into 4GB files) to work over USB but don't know how to make OPPO play them in sequence. As it stands for me, the USB and DLNA capabilities are just toys as I can stream any format (OPPO no wav file support, wtf?) from my NAS through a HTPC.
