Originally Posted by
dkuster
I've got Asset uPnP running and transcoding my lossless wma music library to LPCM.
I don't know if I'm doing something wrong, or if this is simply not possible. Is anyone able to play an entire album?? It seems that all I can do is select one track at a time.
I created m3u and pls playlists and put them in the music folders, but the Oppo doesn't seem to see them. What now
Not sure about the playlists issue, mine haven't worked either but that may be because I'm running it in VMWare. On your first issue, mine advanced to the next track automatically in my custom "bits" container and the "album" container.
rdgrimes
I've just glanced through the log files available in Asset, and I think you may find what you want in there. You have to turn the logging on in the advanced settings and play some files.
You are right, the log does provide the necessary clues to get streaming of 24/96 audio from Serviio. I've grown fond of Asset though.
I still need the results of the Intel uPNP browser to find out what formats the Oppo can truly handle. Our early information has proven inaccurate with kwolfman streaming ISO successfully.
For example, using this tool, I can see what formats I have configured to stream from Twonky. The PN= string is essential. I'd love to just download the string list from DLNA.org's site but they want $10k for a username or 350 franks for the document. From here you can see Twonky outputs the wrong LPCM flags and ID for the Oppo to do 24-bit LPCM (comparing to the debug log from Asset):
Code:
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00f00000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00f00000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00f00000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00f00000000000000000000000000000,http-get:*:audio/L16;rate=32000;channels=2:DLNA.ORG_PN=LPCM_low;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:audio/L16;rate=24000;channels=2:DLNA.ORG_PN=LPCM_low;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:audio/L16;rate=16000;channels=1:DLNA.ORG_PN=LPCM_low;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:audio/L16;rate=12000;channels=2:DLNA.ORG_PN=LPCM_low;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:audio/L16;rate=11025;channels=1:DLNA.ORG_PN=LPCM_low;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:audio/L16;rate=8000;channels=1:DLNA.ORG_PN=LPCM_low;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_PRO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_PRO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_H263_MP4_P0_L10_AAC;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:image/png:DLNA.ORG_PN=PNG_TN;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=00f00000000000000000000000000000,http-get:*:image/png:DLNA.ORG_PN=PNG_LRG;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=00f00000000000000000000000000000,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAPRO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=01700000000000000000000000000000,http-get:*:image/jpeg:*,http-get:*:audio/x-wav:*,http-get:*:audio/mp4:*
Having this information from the Oppo is the Rosetta Stone for creating the ideal streaming user profile.
