I was hoping I could get a little input from the group on an HTPC I'd like to build and have a few miscellaneous questions as well.
I have tooled around on my pre-built Dell, HP, etc. computers but limited to swapping out dead hard drives, power supplies and the like. I have been tinkering around with the idea of building my own PC and think I am finally going to take the plunge. After an extensive amount of research, I think I am going to move forward with the recommended Intel/Intel high end ATX package suggested by renethx (brief summary with a few slight changes below).
CPU: Core i5 750 2.66GHz LGA1156, $196.
CPU Cooler: Zalman CNPS9500A LED, $41, with Zalman ZM-CS5B Clip Kit for Socket 1156/775, $3 (necessary to attach the cooler to the LGA1156 socket).
Motherboard: ASRock P55 Extreme LGA1156 Intel P55 chipset ATX, $140.
Memory: A-DATA HY63I1B16K DDR3-1333 2 x 2GB Kit, $88.
Graphics Card (ATI): HIS H575FN1GD iCooler IV Radeon HD 5750 GDDR5 1GB, $145.
HDD: WD Caviar Green 1.5TB 32MB/SATA-3G HDD, $109.
PSU: Corsair TX650W CMPSU-650TX 650W, $85.
Case: Zalman HD503 ATX
Optical Drive: SAMSUNG 8X BD-ROM Model SH-B083L
I am interested in playing FLACs through this PC on a 7.1 speaker set up. Will I need a separate sound card or additional software to accomplish this? I will be connecting this HTPC to an Onkyo receiver via a 10' HDMI. Should I run the HDMI cable from the motherboard or the graphics card? If I run it from the graphics card, should I run a SPDIF Toslink for the audio?
I don't currently play a lot of PC games, but I would like the system to be able to handle it if possible.
I would like to use this HTPC to be able to record 1080p shows and stream them to other PCs I have connected via Cat 5 throughout the house. I am very interested in purchasing the Ceton Quad Cable Card card when it becomes available. Do you think the system as I put it together above would support recording from four different tuners and streaming the 1080p over the gigabit Ethernet or would I need more processing/graphics power for that?
From a technical perspective, how many hard drives do you think I could install in this configuration?
Do you see any compatibility issues with any of the items I have listed above? Finally, though I would like to get started putting this together ASAP, I don't have a deadline, so if you know of a product releasing soon that would be a smart upgrade, please let me know.
Thanks in advance for any help you can offer!
