I've searched through this forum and posted a few threads which have been very well received it seems.
I started ordering my components for my Linux based HTPC build having been playing with the latest XBMC release on my Linux workstation.
One thing I have noticed is that the scraper for videos are not 100% accurate & I don't expect them to be.
In the Linux environment what tools are available to edit XBMC's database directly?? In Mediaportal for example in the setup app you can directly edit entries for Videos/Movies changing anything from the description to the graphic used.
In the windows environment there seem to be a few easy to use tools mentioned in the forums. What exists for the Linux environment?
