Hi,
Pictures of my Energy ESW-V10 Subwoofer (Unboxing)
Specifications
System Type Bass Reflex with Rear Firing Dual Ports
Frequency Response 23Hz-120Hz +/- 3dB
Amplifier Power Output 300 Watts RMS, 1200 Watts Dynamic
Woofer 10 (25.4 cm) Woven Composite Fiberglas Cone with Patented Ribbed Elliptical Surround
Variable Low Pass Filter 40Hz-120Hz @ 18dB/octave
Variable Phase Control -180° to +180°
Power Mode Switch On/Auto/Off
Inputs Line In/Sub In & Speaker Level In
Overall Dimensions inches: 14 5/8 x 14 5/8 x 15 5/8
mm: 371.5 x 371.5 x 396.9
(add 2 1/16 (52.4mm) for feet)
Weight - 39.7 lb / 18 kg
Crossover Filter Switch Active / Bypass
Voice Coil Diameter 2 (508 mm)
Finishes High Gloss Black Polyurethane
Specifications
