AVS › AVS Forum › Other Areas of Interest › Car Audio, Video, and Nav › Help choose new speakers....please help
post #1 of 8
hey guys, just wondering, which do you guys suggest are better brands?
im looking to change my car audio speakers, so i need a pair of 6x9's and a pair of 6.5's, at the moment i have Alpine Type-R's SPR-69's and a pair of SPR-17s, so i was looking to upgrade...any suggestions, because i was thinking of either
DLS
Infinity
Boston Acoustics
Focal
MB Quartz
which one of these would you suggest are the best brand for car speakers?
(lets put budget aside and just decide if money wasnt an issue)
post #2 of 8
if u have the budget for it, look into dls and dynaudio
post #3 of 8
how about JL Audio? they arent better?
so the best ones out of that list are DLS and if i have the budget for then DYN Audio?
would JL Audio go with those 2, or the rest of the ones?
post #4 of 8
Jl audio comps are nothing special
they're higher end subs are pretty nice(w6,w7) but they're overpriced and there's better stuff out there for the money
what's wrong with the type r's?
post #5 of 8
I went with all Infinity Kappa and they sound very good. There is also Infinity Perfect which cost more.
post #6 of 8
I'm running pioneer A series coaxial up front with 260 watt max and pioneer G 6.5 coaxial in rear on a 4 channel amp and am happy with it and it didn't cost that much. Im planning on upgrading to comps soon once its warm out and i can work outside
post #7 of 8
elite-fusion; You can't let someone tell you what is better, especially on the internet, when it comes to speakers. The subject is just too subjective. How do you know if their definition of "better" is the same as yours? How do you know even if the person giving the advice has listened to all options proposed in the same environment to know accurately the differences of each?
The only thing you can do is go down to audition the options for yourself. That way YOU can decide what sounds best to YOU. Then purchase the one's you like best.
post #8 of 8
This is very true what I like alot of people dont so it is best to go and sample them for yourself
  Back to Forum: Car Audio, Video, and Nav
