Hi all,
I've been looking at the SuperSat 50 speakers as the solution to wall mount speakers around my 65" flat panel display. I'm thinking 2 fronts and a center. Everything I've read about the speakers has been positive, and MSRP is $500 per speaker ($1500 total).
Now I see the new SuperCinema 3D Array is available, and initial feedback is very positive considering it's a 3-in-1 soundbar type of a solution for the front stage. At 49" wide it will fit nicely under a 65" flat panel. MSRP for this product is $1000.
So, that brings me to my question... what is better about 3 SuperSat 50 speakers (2 fronts and a center) compared to a single SuerCinema 3D Array that justifies the additional cost? What do you think? In general, performance from each solution seems to be great either way.
My primary use for the speakers will be for movies, and I plan to combine them with a pair of SuperSat 3 speakers in the rear (5.1 surround).
Here are the specs for each product from the
GoldenEar web site
Product: SUPERSAT 50/50C
Dimensions: 26-3/4˝ H (W) x 4-3/4˝ W (H) x 2-1/2˝ D
Weight: 7 lbs
Freq Response: 60 Hz - 35 kHz
Efficiency: 92 dB
Impedance: Compatible with 8 ohms
Drivers: Two - 4-1/2˝ High-Definition Cast-Basket MVPP™ Mid/Bass Drivers
Two - 4˝ x 7˝ Quadratic Planar Low-Frequency Radiators
One - HVFR™ High-Velocity Folded Ribbon Tweeter
Recommended
Amplification: 20 - 200 watt/channel
Product: SUPERCINEMA 3D ARRAY
Dimensions: 49˝ W x 4-3/4˝ H x 2-3/4˝ D
Weight: 20 lbs
Efficiency: 91 dB
Drivers: Six - 4-1/2˝ High-Definition Cast-Basket MVPP™ Mid/Bass Drivers
Three - HVFR™ High-Velocity Folded Ribbon Tweeters
Recommended
