Are they worth what they're charging
The $1,249-each Triton Two three-way tower, which is 5.25-inch-wide and 48-inch-tall, features black cloth that wraps around the whole curved-back cabinet. It features two 4.5-inch upper bass/midrange drivers with multi-vaned phase plug, with one driver above the HVFR tweeter and the other below. The built-in 1,200-watt powered subwoofer system consists of two active front-mounted 5x9-inch flat quadratic planar (racetrack) drivers and two side-mounted 7x10-inch quadratic planar passive bass radiators.
* The slim two-way SuperSat 50 left-right speaker and its center-channel version, the SuperSat 50C, both at $499 and both suitable for wall mounting because of their 2.5-inch depth. Their other dimensions are 27 inches and 4.75 inches. They feature two 4.5-inch round bass/midrange drivers, which flank an HVFR tweeter, two flat quadratic 4x7-inch passive bass radiators, and piano-gloss-black extruded-aluminum cabinets that curve back at the top and bottom. An optional base is available for the left-right model.
* The SuperSat3 small satellite, available in a horizontal center-channel SuperSat 3C version, each offered at $249. The SuperSat3 models can also be used as surround speakers. All come with included shelf stands but are suitable for wall mounting because of their 2.7-inch depth. Their other dimensions are 12 inches and 4.75 inches. Their piano-gloss-black cabinets are made of marble-filled polymer to make them non-resonant.
* The $499 ForceField 3 and $699 ForceField 4 powered subs, made of high-density MDF in matte-black finish. Both are trapezoid-shaped with rounded edges. The ForceField 3 features 1,000-watt amp, 8-inch front-mounted driver, and bottom-mounted 9.6x11.4-inch quadratic planar passive radiator. The step-up model features 1,200-watt amp, 10-inch front driver, and 11x13.9-inch bottom-mounted passive radiator.
The speakers can be assembled to create three different 5.1-channel home theater speaker systems.
At $1,750, the SuperCinema3 consists of four SuperSat3 speakers, a SuperSat 3C center channel, and a ForceField 3 subwoofer.
At $2,700, the SuperCinema 50 system consists of two SuperSat 50 speakers, a SuperSat 50C center channel, two SuperSat 3 speakers, and a ForceField 4 sub.
The $3,500 Triton Cinema system consists of two Triton towers, a SuperSat 50C center channel, and two SuperSat 3 speakers.
