I'm considering pairing a tube preamp with a SS amp for my new stereo setup. When doing this, I've read that, to match the amp and preamp, I need to ensure that the input impedance on the SS amp is sufficiently high, relative to the output impedance of the preamp.
Now, the way I'm intending to set up my system is to use the sub for "bass augmentation," where I use the high pass filter on the sub to only run it at frequencies below where the mains roll off. To do this, I plan to split the preamp outputs, running one set from preamp>sub, and another set from preamp>amp>mains. My question is, since I'll be running one set of preamp outputs directly to the sub, do I also need to sure that the input impedance on the sub's amp is sufficiently high, relative to the preamp's output impedance?
