AVS › AVS Forum › Display Devices › Rear Projection Units › Samsung DLP "White Dots" FOC repair qualification
Samsung DLP "White Dots" FOC repair qualification - Page 4
post #91 of 95
Hi Phil,
I do not know where to get the chip, you could call various TV repair places in your area. Dh and I have decided to go ahead and have the repair done by a professional. My dh is fairly handy with electronics, but he erred on the side of caution with this. From reading around, there is a YouTube video out there on how to replace it. You could post a new thread asking where to buy the chip, I'm sure someone here probably knows.
Good luck!
post #92 of 95
Same is happening to mine. The HL67A750. EDIT: HL-T5689S
White dots every where. And from the previous posts, it sounds like the late models aren't on the list of recalls and as such do not receive free chip replacement.
I guess we'll have to buy ours from here:
http://www.shopjimmy.com/samsung-mitsubishi-toshiba-4719-001997-dlp-chip-2.htm
Any other suggestions?
EDIT:
Sorry, I mixed up my 56inch with my 67 inch TV which is the later model and not broken(yet knock on wood)
Is the HT-L series covered by the recall?
Edited by yucky - 7/28/13 at 7:58pm
post #93 of 95
Hi,
Can you tell me how to fix the white dots that are showing up on my Samsung 82 inch?
Thanks much!!
post #94 of 95
EDIT:
The following models were covered for the HLT series - 4675SX/XAA, 5055S, 5055WX/XAA, 5075SX/XAA, 5675SX/XAA,5076SX/XAA, 5676SX/XAA, 6156S, 6156WX/XAA, 6176SX/XAA,6756WX/XAA,and 7288WX/XAA
However, someone mentioned in this thread said that they were no longer covering these after Feb. 2nd. You can call 1- 888-899-7602 and find out.
Originally Posted by mirali View Post
Hi,
Thanks much!!
You will need to replace the DMD chip on your DMD board. You can go through this thread and find a ton of info. You should also be able to find some how to videos on youtube. You may not find your exact model, but you can get an idea on the basic process.
post #95 of 95
This is a very good tutorial that worked out for me:
https://www.youtube.com/watch?v=JBz3TanJv0Q
  Back to Forum: Rear Projection Units
