Originally Posted by
mikieson
I dont think thats a good way to judge the quality of speakers just because they dont have all the numbers and such.
It is a perfectly reasonable way to judge a driver. If the manufacturer can't be bothered to give even the most basic data about the driver, then I wouldn't look at the driver any further. Without the T/S at a minimum, you can't design a reasonable box for a given driver. A full set of Kliipel's would be even better.
mikieson
I would put any "car" sub against any "home" sub any day.
Some yes, some no. Peerless for example have two variations on some of their sub drivers, with one version having a higher Fs as the cabin gain in a car will bring the LF up to flat. Same driver/box in a home will not have the LF response that a home driver will.
mikieson
A sub is a sub as long as you know how to get what you want from it.
Not really. Differences in motor and suspension design and implementation will determine distortion performance as well as usable Xmax and Xmech, thermal issues in getting rid of waste heat and consistency of performance over the life of the unit.
Many of the car sub drivers I have seen (not all) are obviously designed with aesthetic 'bling' appeal being the major design consideration.
