Originally Posted by
derekjsmith
Well the ColorMunki Photo/Design is a Spectrophotometer so that in itself is a plus. It is also designed by the same guys that do the i1Pro. All of its accessories are built in like the dark offset, ambient diffuser, just turn the dial to the mode you want. The downside currently is the ColorMunki does not have a tripod mount we are working on a design.
Sounds like a pretty good endorsement given the cost of the ColorMunki vs the i1Pro. A question, however, there is another thread
http://www.avsforum.com/avs-vb/showt...php?p=17190865, which talks about the UV filter in the ColorMunki being a problem for CalMAN. Is that filter a problem? Is it used when the device is in projector mode?
Also, will either version of the ColorMunki work with the CalMAN software, I'm interested in getting the Design version (instead of the photo), since it comes with the Pantone information, which I would find useful in my artwork. The specs look very similar.
Will you be offering a home version of the CalMAN software for the same standalone price (I don't see ColorMunki listed)..
CalMAN Home Edition - Software Only
For Spyder2, Spyder3, EyeOne Display2, DisplayLT, DTP-94, ColorPro II.
3v100
Also, when can we expect V4 of the software to be available, and would people purchasing V3 now get an upgrade or would we have to pay more? The Amazon price of the ColorMunki + the standalone software price has my trigger finger itchy.
-Jim
