AVS › AVS Forum › Display Devices › Display Calibration › The VideoEq -- A low cost external grayscale/gamma/cms tool
The VideoEq -- A low cost external grayscale/gamma/cms tool - Page 15
post #421 of 709
New build out.
_____
Axel
post #422 of 709
I've programmed a tool for the VideoEq that enabling touch RGB Levels and luma for 11/21 points of the grayscale with the possibility of extending to the WTW (105% and 109%) and with control of the parameters of the CMS.
I leave the link in case anyone does not usually visit the forum Calman:
http://www.spectracal.com/forum/view...hp?f=46&t=1982
Best regards.
post #423 of 709
I posted my results calibrating my JVC DLA RS2 projector. The Video EQ Pro rocks.
http://www.avsforum.com/avs-vb/showt...0#post18566590
Dave
post #424 of 709
Dave
They look good Dave, I'd recommend trying to create an offset for the sensor so that you face it towards the projector. I did this with my HD350, Chromapure (I'm sure Calman allows this too) and i1-LT, so that I can get good readings down to 5 IRE and use the VEQ controls to get these IREs spot on too. It will help to get the best shadow detail (though of course it might be spot on anyway, you just don't know for sure).
post #425 of 709
Not sure if this has been already covered..
Will the videoeq flatten out a greyscale curve? after calibrating my Panasonic Plasma, the greyscale shows a hump in the 80% range.. the only way I have found to flatten out the gamma was to reduce contrast resulting in very low light output (about 24ftl) .. This is not ideal..
If the videoeq can flatten out the curve, will I need the Pro version? or can the basic version do the job?
Thanks for any answers..
post #426 of 709
For grayscale and gamma adjustments you can get away with the basic version. However if you have a non-THX Panasonic plasma you'll benefit from the CMS controls in the Pro as well.
post #427 of 709
The new "Basic" version of the Video EQ now comes with a 6-axis CMS and is on sale through May for only $699. I think the only difference now is that the Pro has remote control capability and more memories.
I have to say that this change in both the functionality and price of the Basic model stings after paying almost twice this much a few weeks ago for the Pro version when I could have gotten by with the new "Basic" version.
That being said, the VideoEQ is the perfect tool for correcting anomalous bumps in grayscale tracking.
post #428 of 709
Originally Posted by Kevin R. Anderson View Post
The new "Basic" version of the Video EQ now comes with a 6-axis CMS and is only $600. I think the only difference now is that the Pro has remote control capability and more memories.
Yeah that is quite a change! I didn't realize they added CMS functionality to the basic version. I would expect a massive price drop on the Pro version as this will more than likely cannibalize sales.
post #429 of 709
Wow this is huge news for me. Now I think I can actually afford one to pair with my non-Elite Kuro.
post #430 of 709
Yes with a firmware update the VideoEq Basic now has CMS with its single custom table. We rewrote the firmware to fix some HDCP issues and found in doing so had just enough room left to wedge in CMS. We are just finishing up firmware updates for the Basic and Pro. For the VEQ Basic we added CMS and better handling HDCP, for the VEQ Pro better handling HDCP. Expect to see the firmware updates out early next week with updated VEQ tools.
BTW, the price quoted above for the VEQ Basic is a May special only so don't expect any price drop in the Pro.
post #431 of 709
I've had nothing but good results with my NE Kuro. Once you go REC709 there's no going back
post #432 of 709
no money yet!!! and I just dropped $300 on the SpectraCal Summer Training Tour, that and I'm needing to save $1500 to replace panels on my MartinLogan speakers and I also want to take either ISF or THX certification classes at some point.
post #433 of 709
no money yet!!!
Minor details
post #434 of 709
From what I've gathered about the Basic version was that it had 4 preset gamma adjustments, rather than the pro version that had 4 programable luminance tables .. would I assume then that unless I had access to the programable tables, I would not be able to flatten out the gamma and woud simply just bump the curve, hump and all up or down to get a higher/lower average gamma?
post #435 of 709
From what I've gathered about the Basic version was that it had 4 preset gamma adjustments, rather than the pro version that had 4 programable luminance tables...
No. The second post in this thread has a set of links. Of those the SpectraCal page hasn't been updated to show the single CMS table but is otherwise correct. You may have read that the gamma LUTs are preloaded or that the tool supports moving the entire LUT up or down but that's a convenience. You have full control of gamma and white point with the VEq.
post #436 of 709
VideoEq Tools and firmware updates: Build 32
Adds CMS support to the VideoEq Basic
Improves HCDP handshake for all VEQ models
post #437 of 709
Derek,
If I were to order one (non-Pro) now before the May 31st deadline on the sale will it come with the latest firmware with CMS adjustments or will I have to update it once I receive it? Any possible free shipping discounts from frequent shoppers?
post #438 of 709
which version of Calman is required to use this device?
post #439 of 709
Derek,
All VEQ's have the latest firmware installed before they ship from us.
post #440 of 709
The VideoEQ can be used with any software (and meter) that can measure gamma, whitepoint and chromaticity. CalMAN is not required. The next version of CalMAN (at the required level which is currently Enthusiast) will provide extra support for the VideoEQ.
post #441 of 709
No version of CalMAN is required. The VEQ has its own tools so you can use any software for taking measurements. But CalMAN v4 Enthusiast and Pro can also talk directly to the VEQ via our interactive chart interface making the process much simpler.
post #442 of 709
A few more questions:
1. Is there an answer yet on whether or not 1080p@72 signals will be passed by VEQ?
2. I also like to know, since I can only add or subtract 0.2 gamma with the VEQ non-pro, will 2.3 yield better results for night viewing over my Kuro's unadjustable 2.1? Also is the only way to toggle between the different gamma modes via a laptop hooked up to the device through USB?
3. The signal chain shows an example of: Blu-ray player -> HDMI cable -> VideoEq -> HDMI cable -> Display. For those of us with receivers I'm guessing swap Blu-ray player with Receiver?
post #443 of 709
I have not tested it, I will have to find out
All VEQ's have gamma adjustments from +/- 100% I'm not sure where you got 0.2?
Yes the VEQ is the last in the chain just before the display.
post #444 of 709
FAQ here: http://www.curtpalme.com/VideoEq.shtm
In the comparison chart at Gamma Adjustment it says VEQ's is fixed and VEQ Pro's is adjustable.
post #445 of 709
In the comparison chart at Gamma Adjustment it says VEQ's is fixed ...
Kal should fix that since you're the second person to mention it.
post #446 of 709
I have Chroma 5 with CalMAN Home. I guess I'd have to upgrade this to CalMAN v4 Enthusiast if that is even possible.
post #447 of 709
Look on their website. They have an upgrade for that. They even have a special on it.
post #448 of 709
I have Chroma 5 with CalMAN Home. I guess I'd have to upgrade this to CalMAN v4 Enthusiast ...
I would assume that as a Home user you have a small number of displays. If you have only one VideoEQ I'm not sure it's worth upgrading.
Every time someone talks about the VEQ and CalMAN 4 I suspect they have incorrect expectations.
post #449 of 709
I currently just have one display I care about - 60" Pio.
Sounds like the major difference between using the CalMAN Home and the
Enthusiast with the VEQ relates to improved integration.
Louis
post #450 of 709
I am also unhappy that the CMS functionality I needed is now included in the cheaper VEQ Basic model. I didn't need the additional Custom memories, IR control or anything like that, but I needed CMS and the Pro model was the only model to fit the bill. I think the Pro model early adopters to date should get complimentary Calman 4 Enthusiast upgrades to properly differentiate the models, as I feel a bit cheated at the moment.
