AVS › AVS Forum › 3D Central › 3D Displays › LG Announces 1080p 3D projector
LG Announces 1080p 3D projector - Page 2
post #31 of 33
Originally Posted by William View Post
Isn't that like saying in 1970 that $1000 for a 19" color was a huge jump (in price) from a $100 12" B&W? Apples and Oranges, they are both fruit but...
Also I paid over 10K for my HD11U projector about 5 or 6 years ago. So this is actually a "first out the gate" bargain.
Maybe but since the $699 720p 3d was just released in 12/09 then early 2010 a 1080p is 10K. Both Apples just one is bigger and tastier then the other. Most will pay $699 now and wait till the other gets closer to $3k ish (pulled that price out of the air no basis in fact.)
post #32 of 33
These two projectors are not comparable... car analogies or otherwise.
$699 for a 720P PJ... 3D or 2D... is a pretty low-bar projector.
Most "entry level" Home-Theater worthy 1080p 2D projectors start in the $2000 range. A decent LCOS or SXRD or DLP solution will run you between $3000 and $10,000 right now... and that's just for 2D. In fact, the 2D LG projector that this new 3D model is based off of is $5K, and since the 3D projector is basically 2-machines-in-one, the $10K price is actually pretty reasonable.
Also, besides the vastly different image quality between a 699 and 10K machine, the method of producing 3D is very different: the LG is using polarized light with no flicker, which would make it easy for a large crowd of viewers since inexpensive glasses will work without the need for active LCD eyewear.
Polarized solutions will be expensive with dual-engine light paths, but will provide optimal image quality. There will also be lesser cost single-engine polarized that alternate left/right even though they use polarized light) as well as active shutter wear front projection systems... these latter two should cost less but there will naturally be trade offs given the different designs.
I doubt that any videophile serious about home-theater and good image quality would be satisifed with a $699 projector with today's technology, given that even 2D projectors at that price point have very compromised image quality.
post #33 of 33
Does anyone have this unit? I have the CF3D and have run into an interesting issue with Blue Ray sourced content. Am wondering if anyone else is having any issues.
  Back to Forum: 3D Displays
