Impossible, and here is why:
First, the circular polarizer method used ‘POLARIZERS’ – polarizers change the way light travels. It changes its ‘plane’ and allows light to transmit in a fixed direction. A plasma can not manipulate light in this way. This is impossible to do with a plasma, even with filters over a screen.
Each of the 2 images itself MUST be generated by a special polarizer with an angle exactly matching the ones for each lens on the glasses respectively.
This could only be done with maybe a special LCD screen with 2 panel layers and 2 separate polarizers for each panel. This could get expensive.
The polarizers can also cause ghosting and other problems.
Anywho, bottom line, polarized Tech for 3D can not be applied to plasma.
