Re Question 4 - the manual states that:
"To connect to the video device using a splitter, make sure to use the splitter compliant with the HDMI 1.3 Deep Color Standard. If you use the splitter not compliant with the HDMI 1.3 standard, this projector may not display any image or not operate correctly."
Although this is specifically mentioning splitters, the spec would apply to the whole HDMI chain. Therefore anyone who is using cables (and any other hdmi device) that is not 1.3 compliant will have issues that are not Mitsubishi's fault. Some information indicates that 'deep color' was part of the 1.3 spec whilst some say 1.3a. The 1.3 spec also introduced a much higher bandwidth capability.
From what I can make out, 1.3 compliant devices and cables started to become available in early 2007 so older cables will not be compliant and plenty of non compliant cables and devices would have been sold between then and now.
Its all part of the great HDMI debacle along with a connector with no locking mechanism
. I have a Canon S5 P&S and it has its limitations when it comes to low light shooting. The next day when I compared that shot to my desktop, the colors were off by 20%, I'd say.
), then painted black out cloth or painting a wall are probably best options. You will be at full zoom at 15 feet, which is good for brightness. I would go to the DIY screen thread--lots of ideas there. Check out the MaxxMudd thread and Tiddler threads. You'll get better feedback there. I used RS-MaxxMudd-LL, slightly grey. It uses flat white paint, silver and gold pearlescent craft paints and Polycrilic satin (like clear varnish) in a specific mix with water. Check out the beginning of the thread in my last message. It gives ideas on paint and gain. The formulas can be found in the official paint thread for MaxxMudd. Tiddler (search older thread) has some good ideas using just Behr UPW flat paint and Polycrilic, especially if you want to roll and not spray the paint on.
