I've posted this in the Screens forum, but it started out more as a general using curtains as a mask thing and then led into a DIY masking system.
Here's the link: http://www.avsforum.com/avs-vb/showthread.php?t=1215344
I'll reattach the sketch (shown at the bottom).
One of my biggest issues is not knowing where to go to get the parts, like motor, encoders, etc.. I know where to get discrete electronic parts. I am designing the circuitry for it now, but it's possible that it is already available as a complete circuit. For instance, can you buy an integrated motor, encoder and processing circuitry to take an IR command and set preset positions for differenent aspect ratios. I have an idea for the circuitry if I have to go the discrete route.
As far as IR or even RS232 go, I'm pretty clueless as to what is available or how to integrate it.
I would appreciate any guidance that you can give. And if you can give me some good sources for the components that would be great.
Greg
Greg
Screen Masking Idea.pdf 15.1396484375k . file
