Originally Posted by
D-Xtreme
I really like your system, since it's almost identical to mine. Only difference is I have a Onkyo 805 receiver. I just purchased the set of Mirage OMD15, OMDC1, & OMD5 (nice speakers). I'm really looking into getting the Emotiva XPA-3 that you have, since the sale is still going.
Has the amp made a big improvement over your Yamaha?
I want to be sure I will tell a difference over my Onkyo before ordering the Emotiva.
Any assistance you have is appreciated!
Yes the amp is an improvement. Do it if you can. Sale ends 7/18 so get it now!
If you can do it go with the XPA-5, wish I would have. I have a UPA-2 on backorder when they start shipping again.
KahunaCanuck
Hey Spur,
Lookin good! I would recommend you pull the center to the front of your cabinet and keep it on the same plane as the left and rights. Try it and see if that helps...
Cheers!
Mike
Thanks. Not sure if pic was taken with speaker where it is now I didn't look, but the center is pulled out and even with the L/R now. Your system is amazing by the way.
