Does it seem deeper also? The soundfield changes now with the move, and it sounds as if you're a bit closer. It's said real bass is felt, not heard, and you're surely feeling it from what you say. Whatever Hz you get, it's definitely deep enough.
It seems deeper to me. I would like to feel it more but I guess that require new subs, SVS Ultra.
What is component access like with the cabinet? Some cabinets are very difficult in this regard. To get to connections in the rear is awkward because of the design. Have you found that to be the case?
Late response. Panels come off of back for great access.
Nice! I noticed your rear surrounds are on what look like wall plates. How are they set up (close-up pictures please). I like how clean it looks, how'd you pull that off?
It is just a wall plate with a hole drilled out and speaker wire pulled through. The wall has a hole cut in it and the wall plate covers the hole up. The speaker is then held up by the top screw from the wall plate.
Great set up, love your new gears and av stand, well done. Thanks for sharing
Added SVS PC12-Plus. This thing is a lot more sub then what I had. I sold my Mirage Prestige S10 but still have the Energy ESW-V10 for now. Thought about adding 2 SVS but right now I don't see how I could justify it. This thing just pounds.
Crap pic but here is my new front with the OMD 28's in place. The Energy sub will probably go away and the SVS is in the back left, right beside my listening position.
