post #1 of 1
1) Under the Graphics menu in the upper left, select Desktops & Displays.
2) In the desktop & displays, you have to go to the bottom where the icon is for the display and right-click on it. Then you get the configure menu.
3) After that you'll get the tabs and can see the one with scaling options
I hope that helps!
