AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Hoping to get some help here
post #1 of 2
Hey everybody, I'm new here and hoping to grab a few tips ,
I'm a college student, sorta set on a goal to make a semi-decent home audio system while I'm here. Last year I got a Sony DAV-HDX265 HTIB system and soon found out that these are not worthwhile to be honest, this is where hopefully I can pick up some quick tips.
I recently bought the Onkyo HT-RC160 receiver for just under $300 shipped. However, I am still using the Sony receiver. I also managed the pick up a pair of older Technics SB-A27's that I currently am using as my front two speakers. Then I replaced the tiny surround speakers from the HTIB with the originally front speakers for the time being. The center channel on the receiver doesn't seem to function at all, so I'm at a 4.1 system with a passive 8"?? sub I believe. Not quite sure on that though.
So the questions I have...
I've been looking at a few different subwoofers, the Sony SA-W3000, and the Dayton Sub-120. They are each $100-150 or so, and seem to have similar reviews in that they tend to be a bit boomy, but they are cheap subs and I know this. So any reasons to choose/avoid either sub, or choosing a completely different sub, hopefully <$150 would be great . And being as this receiver is a 7.2, should I go ahead and make it a full 7.2 with two subs, or would 1 be adequate?
The next speakers I'm looking at are the Sony SS-F6000 speakers.
I've read some pretty good reviews on these speakers as well and found them for $98 a pair so I was thinking of getting these to possibly replace my Technics speakers as the front L/R channels, putting the Technics either on the side or behind the couch, depending what sounds better, and continuing to use the original Sony front speakers as wall mounted surrounds or something of the sort.
One last note that I can think of right now, the speaker wire that came with the HTIB and I'm still using is either 16 or maybe even 18 gauge wire, is it noticeable to use a lower gauge, and if so, should I buy some new wire? Most forums I find I see people using 12 and sometimes even 10 gauge wire, so I was thinking I should step it up a bit.
So, sorry for the long winded write up, but any suggestions and comments would be fantastic!
post #2 of 2
First off, most of the sound from a movie is thru your center channel speaker so you want to get that working. Second, you dont need "large" speakers for your sl, sr, speakers. Not a whole lot of sound comes thru them, it is mostly accent sounds. Using 2 subs instead of one is all preferance. I personally have 7.2, and enjoy it. Onkyo makes a really nice 5.1 speaker package and someone is selling there setup in the "audio gear for sale" section of this forum for only 199. Very good deal. Finally, 14awg wire should be plenty for whatever you are running. Hope this helps.
