Has anyone used the AVSHD 709 calibration DVD on a Mitsubishi x737 Series TV, and tried the Resolution Images (Section C #88)?
My WD-73737 has an unusual display when I try to view Checkboard, Single Black Pixels, 1 Pixel Vertical, or 1 pixel Horizontal Resolutions test. The 2 & 3 pixel resolutions test display fine. Other than not displaying the patterns above correctly, the TV has amazing clarity and PQ when watch Blu-ray and other HD sources.
Any clues to what's going on?
http://www.avsforum.com/avs-vb/showthread.php?t=948496
Update:I found out if I go into the Service Menu and remove all geometry correction - the 1:1 pixel pattern will display correctly. I didn't notice any picture quality improvents with geometry correction set to null.
