I am currently in the process of prewiring my living room. I'm debating between 5.1, 6.1, and 7.1. I will probably drop wire for 7.1 and if I decide on 5.1 so be it. The problem is that my 15'x20' living room has quite a few openings, doors, windows, etc. so speaker locations for surround and rear will have to be high up on the wall near the ceiling.
This is primarily a living room and I am adding surround sound for both resale value and my own enjoyment, so I'm looking to get a decent system for as cheap as possible that sounds fine and looks good. I don't need extreme sound quality, but I would like something that enhances the viewing experience. I'm also looking at spending less than 2k on the speakers if possible.
The house is a 1914 Craftsman house, so we want the look to not be overly modern, and would prefer the speakers to be very low profile. We want everything to "fit" as much as possible with the era (I know this is weird to say when adding surround sound to a 100 year old house, it won't match the period, but I want the speakers to be as unnoticeable as possible). This is why I have been leaning to in wall speakers to be low profile, but I am concerned about the sound quality. The front speakers can possibly be free standing speakers, and the main center speaker will probably be mounted above my TV (7-8 feet high). The surround and rear speakers will have to either on or in-wall speakers.
The issue is that the rear speakers will have to be at 7-8 feet high. Will this pose a problem for in-wall speakers? which can't be tilted? The same goes for the surround speakers. Unless I place them in front of the listening area, they are going to have to be close to the ceiling about 7-8 feet high.
Basically I'm wondering if placing speakers this high will degrade the sound quality (btw this room will also be used for playing music through my whole house audio system).
Should I definitely stay away from in-wall speakers for my center and front speakers? I can probably get away with free standing speakers in the front.
Am I going to have problems mixing and matching in-wall, on wall, and free standing speakers?
Can bookshelf speakers typically be mounted on a wall? If so how?
Richard
Richard
