I've been trying for many months to get the new Samsung HD-Dvr in St. Pete Fl (Brighthouse) to no avail. When recently I called for a service appointment because my modem went bad, I also asked again about the new box. To my surprise they didn't have the Sammy still, but did have the new Cisco 8640HDC. So I have it here now.
Mine has the 320 GB HDD (WD3200AAJS) which does 180 hours of SD or 40 hours of HD.
Manual/Specs
So far I don't notice any major speed differences in the interface, but I am happy with the extra space. I recorded 2 1hr shows in HD, they only took 2% each. I do find there is a noticeable lag with all remote control functions.
This box has a major bug when using the HDMI connection! If you have your box set to 720p or 1080i resolution and either shut off the box or change your TV to another HDMI input, it will reset to 480 (even if 480 is not checked). If you have this box, call your cable provider and complain so that we can all get this fixed!
Workaround: It has been confirmed that you can use the component connection instead to avoid the problem for now.
This exists up to the current firmware version 3.1.3_3. To check your firmware version; while watching a channel just hold the Select button down on the remote for about 10 seconds until you see a flashing icon on the unit's display, then press the down button. You will see Diag on the display for a few seconds then the diag screen will pop up over the show you're watching. ODN version is near the bottom of the first page right above the date of the unit's last reboot.
Manual/Specs
