AVS › AVS Forum › A/V Control & Automation › Home Automation › Elk M1 to Denon AVR
Elk M1 to Denon AVR
post #1 of 4
I have a Denon AVR-4308CI. This model allows me to send commands to it over TCP port 23.
I have an Elk M1 Gold and an M1XEP interface. I have set my Netgear router to assign a static IP address for the Denon.
Is it possible to get Elk RP to send a string like PWON (Meaning "main PoWer ON") to a specific address like 192.168.0.96? I would like to wake to music, and issue the Power On command at, say, 6:30. (The Denon with the in-ceiling speakers would be a lot better than the current AM/FM clock radio.) The Denon also lacks a sleep feature, and I would like it to turn off 30 minutes after a task ("Good Night") is executed. Two-way RS-232 is not really needed for these tasks, and I will only be using a handful of commands.
Thanks for your help.
post #2 of 4
Thought that question sounded familiar, saw it at cocoontech.
I would think it would be easier to control the 4308 using the serial interface, from the Elk, but I really don't know.
This document details the M1 serial protocol, and it also describes some IP addressing - 4.3 Send ASCII String to IP Address, p. 16.
post #3 of 4
Sounds very possible via RS-232 but IP.. Don't think so.
post #4 of 4
Yes, I have cross-posted on Elk Dealer forum and CocoonTech. I ventured onto AVS because those questions have gone unanswered.
The post to the document was just what the doctor ordered! I'll hunker down and then report my progress. Thanks.
  Back to Forum: Home Automation
