AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Jikkjack's DIY Horizontal Masking Documentation
post #1 of 12
As promised - here is the documentation for my DIY IR Controlled Masking System. I am happy to answer any questions and make updates to the documentation on request. I will update the version number as updates to the documentation are made.
Open:
Closed:
And Video...
Edited by jikkjack - 2/1/13 at 12:35pm
post #2 of 12
Putting that instruction PDF together for others is admirable. Thanks for taking the time and effort.
post #3 of 12
AWESOME!!!!!!! Will this transfer to a CIH version? I really would like some info on how you did this and am very impressed.
post #4 of 12
Thanks Jason - bookmarked for HT MKII (when ever that is).
Be good to add links to where you got the parts.
What was the final cost?
Great Job,
Mark
post #5 of 12
Thanks Mark. Final cost was about 300 dollars and most of the parts came from av-outlet.com.
Thanks adammb. I don't see why not. Check out this thread from another forum member ScottJ007. He has a solution for 4 way masking that is very nice. He used a different motor configuration but other than that - some of the design elements are similar.
http://www.avsforum.com/avs-vb/showthread.php?t=941076
post #6 of 12
That is Phenomenal! Good job, I was always wanting to do a masking system but wasn't quite sure how to go about it.
cheers,
JJ
post #7 of 12
That is really nice. I am checking out your PDF now. Thanks for all the info
craigr
post #8 of 12
May I suggest that you also post this in the DIY subsection of the Screens forum? A lot of folks do searches for masking there.
Nice job.
post #9 of 12
That is awesome!
post #10 of 12
That is simply genius. My new HT build thread is focusing on (among other things) building a screen with motorized remote controlled integrated masking. A recent post in my thread linked me to your PDF instructions and I was blown away. I do not plan on building a false wall, do you think I could still incorporate your system into a DIY screen only? I realize the frame for the screen will be bulkier than a simple screen only frame, but that's more than acceptable.
One question about the remote controlling of it, from what I gathered the motor allows you to set 3 pre-determined stop points; top, bottom, and a custom one. Does it also allow you to move the masks to any position you desire up or down without programmed stops. What I mean is does it allow control of the motor up and down when a button is held until it's at the right position?
Thanks again for sharing all of your hard work and experimentation, it is a huge help to those of us that would like to follow in your footsteps!
post #11 of 12
Thanks guys...sorry for the delay in responding.
The feature you are describing is absolutely possible. It is a jog feature. You can jog the masks up and down in small increments.
post #12 of 12
Hi, I'm new to this forum, and I'm not sure i know my way aroun here yet - I know this an old posting, but that PDF that is mentioned in this post, where do I find that ?
Awesome job, I've been looking for someting like this, that is affordable and build-able.smile.gif
