AVS › AVS Forum › HDTV › HDTV Technical › Coupon Eligible Converter Box (CECB) › CECB onto a All in Wonder Video/tuner card ??
post #1 of 10
Can I put a cheap CECB such as a RCA DTA-800 or ANY CECB between my antenna and my aTI 8500DV-All in Wonder Video card/tuner and be successful at it?
thanks
post #2 of 10
A CECB only outputs SD (generally composite video and stereo analog audio, a few models have s-video output) or channel 3/4 RF modulated mono audio. If your All in Wonder Video/tuner card can accept this as input - you'll be fine. You're NOT going to get HD out of a CECB though.
post #3 of 10
You'd be better off spending the money on a new ATSC compatible tuner card, which would allow you to watch and record HD.
post #4 of 10
thanks
Yes you can.
The problem is that there is no easy way (that I know of) to change the channel on the converter box using the computer. Technically it's possible for the computer to control the box using an IR blaster, but you would have to find the software to control it.
If you are only recording a few shows you can just manually change channels on the converter. There are a few models of converters (DTV Pal, some Zenwells) that have "VCR timers" built into them; they would let you change channels but you would have to program the channel changes on the converter and program the recording times on your computer.
post #5 of 10
I have a couple of them set up to do this (using Hauppauge capture cards) and the picture quality is very good, better than any analog cable or OTA recording you would have made in the past era.
Note the limitations listed by "smpowell".
The Zenith boxes are one of the best if you have to leave a box powered on for extended periods of time. (turn on in the morning to record something before you get home in the evening)
post #6 of 10
Also, the Artecs are sort of Zenith/Insignia clones (same major chipset and very low power consumption); I mention this because they can still be bought new.
I see Zinwells are still available at Amazon with free shipping.
I spotted some DTV Pal types too but one was refurbished (the Plus).
post #7 of 10
Did you find a way to control the converter using the computer?
By default all CECBs are set to auto shutdown after a few hours. But they all have a place in their menus to turn off this feature.
If I were doing this with a non-"VCR timer" converter, I'd go with the Zenith or Insignia models with APT. The tuner is good at handling multipath problems (Better than the RCAs) and the metal case is good for disapating heat. The only thing I don't like about the Zenith/Insignia is the "cyclops eye" LED on the front. I fixed this by taping some red plastic over the LED. That way it only lights up when a power failure has reset the converter to standby mode.
post #8 of 10
Another idea is to put a piece of dark tape with a pinhole in it for the LED. I had to do this with a piece of electrical tape on my Zinwell (VCR) so that my Channel Master (TV) remote wouldn't conflict with the Zinwell; that is the tape was to cover the Zinwell IR sensor but it's so close to the LED that I put a pinhole in it so I could still see the LED.
post #9 of 10
I haven't even tried to set up a blaster but I think the one called USB UIRT is probably the best hardware but it requires third party software to operate and none of them seem to be free.
The blaster that comes with the Hauppauge cards is not a learning type AFAIK and they have not been very good at upgrading the software for new devices.
I just leave the box on in the morning.
post #10 of 10
The TRT seems to have the best timer of the options available.
If you have multiple inputs, you can run more than one box too.
I run one into L-1 and one into F-1 on the vcrs and I could run one or two into analog as well.
I can set the vcr to record from L-1 and F-1 and then when the vcr is set, the TV defaults to the analog feed through the vcr, in my case the F-1 box.
That's two choices without even setting a box timer, from S-video too.
I may have some extra timer boxes available if you need one.
