AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-80 Owner's Thread
Official OPPO BDP-80 Owner's Thread - Page 103
post #3061 of 3926
Originally Posted by rdclark View Post
It's hard to say how much of an improvement you might hear, if any. Those high-bitrate lossy tracks sound a lot better than standard DVDs. And while you'd be getting lossless audio from the Oppo, you'd be giving up whatever digital processing your Denon is contributing to the sound of your system, and trading it for the rather rudimentary versions of bass management and speeaker timing offered by the Oppo.
On my system, for example, it's important that I be able to set a different crossover frequency for the center channel than for the mains and surrounds, and yet a different one for the rear surrounds. The Oppo only offers one freq for all speakers. Also on my system I have Audyssey room correction, which contributes signivicantly, but would be bypassed using analog inputs.
There are other factors to consider, such as whether you might hear a difference between the DACs in each device, and how revealing your speakers are of very subtle characteristics in the sound.
Personally, I'd save my money towards an AVR upgrade if I already had a BD player. Modern AVRs with HDMI and room correction really can make a bigger difference than the subtle one between lossless/analog and high-bitrate lossy in many situations.
thanks for the explanation, and this is exactly what I thought.
post #3062 of 3926
Anyone having problem playing "Fame (1980)" (Region A, US Version) bluray on the BDP-80?
My disc were stuck in there just after the Warner logo...the BD-J won't even load and the time shown were 0:00:00 and just stuck there, have to power off and on to get the BD out.
I've tried 3 times and all same result.
So I just put the BD in my Dune BD Prime 1.0 and it played and go through the BD-J without any problem (that's where I knew it had a BD-J loading logo with a spinning disc)
post #3063 of 3926
Did you try this procedure: What do I do if a Blu-ray disc will not load or play, or if it freezes the player?
-Bill
post #3064 of 3926
My BD-Live is always OFF and I did not connect the player to the network.
Same as my Dune BD Prime, the BD-Live is always set to OFF but it play the BD with no problem
post #3065 of 3926
Nevertheless you still need to clear persistent storage.
post #3066 of 3926
How is the OPPO BDP-80 with DVD upconversion compared to the PS3?
I need a Blu-ray player with really good DVD upconversion, but my budget is around $250-300.
I will only be using it for Blu-ray and DVD's, so I didn't really need any other features, such as internet, audio features, CD's, etc.
I'd just like a no thrills, basic Blu-ray player that plays Blu-rays and DVD's as good as possible, within the $300 price range. Does the BDP-80 fit that?
post #3067 of 3926
I will clear the persistent storage and try again...
newsnerd,
the BDP-80 had a very good upscaler chip but not the best out there, IMHO, thet're on par with PS3 upscaler.
The BDP-83 have the ABT chip which is better.
If your AVR comes with a really good upscaler like ABT or HQV Reon, you can use the BDP-80 as a transporter and let the AVR do the upscalling.
post #3068 of 3926
See the DVD column in Winston's rankings: http://winstonsreviews.com/?page_id=63. He has specific test results on another page.
The BDP-80 has been a very solid player from day 1 (and indeed during the beta period before that). It inherits all the hard work that went into the more expensive BDP-83.
Are you sure you want no thrills?
-Bill
post #3069 of 3926
I just looked at Winston's rankings for the OPPO BDP-80, and it seems he rated the BDP-80 a "9" for DVD, and the BDP-83, a "10" for DVD.
I'd think a "9" for DVD should be fine for me. I don't need (or expect) to have my DVD's look like Blu-rays, but I wanted my DVD's to at least look as good as they would on a regular DVD player hooked up to a CRT.
So in the $250-300 price range, the OPPO BDP-80 is most likely better with DVD upconversion than anything else I could buy, such as from Best Buy, etc?
Thank you!
post #3070 of 3926
Thank you!
yes - if i had to bet money on it - i feel very good about the BD 80 doing a better job then most players out there - i cant say 100% just yet - i didnt get mines in yet - i have experience with oppo - i have the 981 and it did a great job on my DVDs - now i am sure the BD 80 will be much better than the 981 - if its even just as good - i will be happy - and if it got a 9 out of 10 - thats pretty good for a $285 --
i didnt care for the other features too much - i already have the Roku box - so i just wanted a great player to do blu rays - dvds - audio etc, with HDMI - so this fits perfect and price is very good if not great - all i added was the back lit remote for $10 -
post #3071 of 3926
This seems to come up fairly frequently.. so I have two questions:
  1. What benefit does persistent storage provide?
  2. If the benefit is small compared to the benefit of clearing it, would it make sense to request that Oppo create a new menu option called "clear persistent storage on shut-down?"
don't want to submit a request if it makes no sense, but this would seem to make sense...
..dane
post #3072 of 3926
..dane
The relative "benefit" is an open question. It's part of the BD specs so it's here to stay. Clearing persistent storage will likely remain a user-intervention-only option due to the fact that many people use it for saving downloaded BD-Live content.
Storage is used by many JAVA-based discs, independently of BD-Live functions. If it gets corrupted it must be cleared before the disc that used it can be played again. Most problems are due to sloppy programming but should clear as soon as storage is cleared. The better suggestion would be to "ask" disc authoring people to program their discs so the storage is cleared when the disc is stopped. Good luck with that.
post #3073 of 3926
Of course not every disc ever produced is going to be perfect, it would be silly to expect otherwise! I'm just thinking if persistent storage isn't terribly beneficial between power-cycles, I wonder if such an "auto-clear" feature would be useful. Does persistent storage mean the disc will load significantly faster in the future? Maybe a more useful menu option would be to support auto-clear of storage if BDLive is OFF. If it's on, require manual intervention...
thinking out loud...
cheers,
..dane
post #3074 of 3926
..dane
Blu-ray discs with java programming use persistent storage for anything they want. At that point your disc player is their computer and it does whatever the studios and authoring houses can dream up. Stuff previously fetched across the network with BD-Live, local settings, game scores, invasion of privacy databases...
If there were an automatic clear setting I would use it. One issue is automatic resume points for DVD and BR discs, but that is actually in a separate bit of memory and could be cleared or retained apart from the main storage.
I do something similar on my computer. Temporary files all go an a ram disk in memory that vanishes at shutdown time. The Firefox browser will delete security-related info when it quits, although I don't use that feature.
Go ahead and write it up for OPPO.
-Bill
post #3075 of 3926
I replied to your question in the "Help Me Choose" thread, where you (tsk, tsk) double-posted it.
post #3076 of 3926
Thanks a lot for responding, and I will take a look there.
However, I didn't double post. My original post, which was posted in the Blu-ray forum, was moved there. I didn't post it in there, though. However, I did post in the BDP-80 thread as well, believing I would get more responses.
If that was wrong, I do apologize. It won't happen again. I'm sorry.
post #3077 of 3926
Originally Posted by expresso712 View Post
let me ask you - when you watch blu rays with DTS MA or TRUE HD - at night with low volume - letting your 7002 do the decoding -
do you hear the center dialogue clear ? i find it hard to make out what they are saying - sometimes they whisper and cant make it out at all -
do you notice that at all ? i am going to see if i let the bd 80 decode and send it to my AVR so i can use the EQ settings - that helps - but having the AVR decode - cant use the EQ -
if you get a chance next time - post back if you are ok and hear clear or have the same issue
thanks
1st I apologize for taking so long to respond-been a busy few days with my house(yeah we upgrade OTHER things too!)
in my experience I have no issues with the center ch at low volumes-to me it seems more often that a soft dialogue track is perhaps the fault of the audio mix(my housemate often complains of this on regular TV).
now I have a small room & only sit about 8 ft. or less from the screen(and center ch.).
I have DRC set to OFF on the Oppo(I disable most digital audio & video settings like that).
also-did you set up your 7002 using Audyssey? I tried it-when I checked the settings they were all over the place(the spkr distances were WAAAAAY off, for example) so I just set it up manually with Avia & an SPL meter. yes I know Audyessy has worked for others & they're very pleased with it-just didn't work for me.
to sum up-most nights if I watch a movie with the 7002 vol. at around -35dB to -40dB that's fine-don't disturb anyone else in the house & I hear the dialogue fine. again note I sit pretty close.
BTW on the issue of DVD scaling the 80 is VERY good-at least on my 56" screen. watching anime(NINJA NONSENSE to be specific) it's very clean with Oppo set at 1080p if you don't mind the pillarboxing. as previously posted GENTLEMAN JIM(early '40's Errol Flynn vehicle) also looks quite nice.
think tonight I'll have a look at my concert video of Johnny Clegg & Savuka & see how it looks. most of the footage is over 20yrs old-interesting to see how it holds up.
post #3078 of 3926
thanks for the response - i did order it - so i guess i will find out myself if it will help me with my issue - either way i am keeping the player - and if it works better for dialogue - thats great -
i dont sit far either - i am about 6 feet away i did use the Audessey setup and works fine for me - the outcome of Audessey depends on the position of where you put the MIC - i have ran that a few times over -
and many times it comes out better than the previous - - i am not blaming my AVR or player etc. - i know its the Mix on the blu ray audio which gives it a low weak dialogue at low volumes - with any other audio format - like Dolby Digital - its fine - sounds good and clear and loud with the center - and i use the EQ settings on my AVR to make it even better -
i am getting it thursday - and should have it set up and going over the weekend - then i have to test it with blu rays as i get them in from netflix
thanks again
post #3079 of 3926
Done.. Good idea about a ram disk.. How do you know how much space you need on your ram disk?
cheers,
..dane
post #3080 of 3926
cheers,
..dane
Bit off topic.
(Linux makes one automatically. It's about 1.1GB on my system).
-Bill
post #3081 of 3926
Bit off topic.
-Bill
(yes, OT, sorry) .. Ahh, you're on Linux. gotcha. life is much simpler in that land. [/OT]
..dane
post #3082 of 3926
Is the BDP-80 ideal with LCD's on the smaller side, or that doesn't matter?
I have a 46" Sony 1080p LCD, with viewing distance around 7' away.
I'm trying to determine if the OPPO BDP-80 is right for me in regards to DVD upconversion, which is really important. The BDP-83 is out of my budget, and I do not need any extra features. Just watching Blu-ray and DVD's.
I should note that I watch Blu-rays/DVD's maybe a small handful of times a month. I'm not a movie buff at all, but would just like good DVD quality for whenever I do throw in a Blu-ray or DVD.
Thank you!
post #3083 of 3926
newsnerd, I feel confident saying that on a 46" LCD the difference in upscaling between the BDP-80 and the BDP-83 will be negligible, if it's even detectable at all.
post #3084 of 3926
There are detectable differences in de-interlacing, but over-all the picture quality will be excellent with either. For mostly movies it's very sensible to go with the -80.
post #3085 of 3926
Thank you very much for the responses.
So on a 46" Sony 1080p LCD, the OPPO BDP-80 should give really good DVD upconversion, and maybe even on par with the PS3 in upconversion?
post #3086 of 3926
By most accounts, on par with the PS3 on any display.
post #3087 of 3926
one more vote for the Oppo 80's DVD scaling prowess!
as I stated earlier I did check the PQ on my Johnny Clegg concert DVD. the main program was recorded in Paris in 1990(rescanned from SECAM?).
it looks VERY good @1080p scaling-definitely better than my old Denon 1920(tho to be fair that's a 1080i player). I don't think you can expect much more from 20 yr old video.
the DVD also has music videos from Clegg's days fronting JULUKA(with Sipho Mchunu) and the scaling is a bit TOO accurate-in that it's obvious these circa '80-'82 videos are unrestored & showing it. not the fault of the Oppo-it can't work magic.
also watched about 1/3 of ATRAGON & again it looks as good as an early '60's Toho Studios effort can be expected to. clean, sharp, plenty of detail(especially the miniatures FX work).
really I think Oppo's disclaimer should be worded more like "UNLESS you have a VERY large display..." where "large" means at least a 73" Mitsu DLP & going up from there. with anything smaller I'd say 99.99999% would be happy to delighted with the Oppo 80.
BTW expresso you said your new 80 was to arrive today. if so let's hear how you like it.
post #3088 of 3926
I'm looking at the two of these players and was set on the 83, however with a little research I don't believe in my case there will be a benefit. I will be running the player exclusively via a HDMI to my Onkyo TX-SR876 receiver and then to a Panasonic PT-AE4000U projector via another HDMI. As I understand it the real benefit of the 83 are when run direct to the display and with 2 channel audio, both of which are none issues to me.
I know the build quality is nicer on the 83 as is the remote, both are not big factors to me. Is the information I read correct or not?
post #3089 of 3926
i like your review of the bd 80 -- making me feel good about my purchase -
it was suppose to arrive today - but Fedex is a bit slow - its going to arrive tomorrow - i will add it to my system and play around over the weekend -
i have a blu ray ready to try out - its From Paris with Love - action -
now i will watch it tonight and then watch again on the bd 80 - to see if i notice any difference with PQ and Audio with dialogue - unless its a bad movie - then i will send it back and wait for the next blu ray to come in -
with DVDs - i know i dont have to test both - i am used to how my PQ is now - and i can tell if theres a difference with out trying both players with the same movie -
let me ask you something - in the settings on the BD 80 -- do you adjust any of them or leave them flat and just use the settings on your TV etc.
i have a 500M and usually leave it on PURE mode - looks excellent - really all the modes look great - i did copy the calibrated settings for my TV -
i wonder if i can improve even more with the BD 80 picture settings -
post #3090 of 3926
Thinking of buying the Oppo 80, would it be an improvement over my current and below listed set up? Thank you for your helping me decide.
Mitsubishi HC3000 720p Projector
