Originally Posted by
MG428
Can someone tell me whether there is any single advantage of BDP-83 over BDP-80 when used with 1080p material via non-source direct and bitstream to the AVR, especially if "Detail Enhancement", "Edge Enhancement" and "Noise Reduction" features of the ABT processor are not used? Does the screen size matter in this regard?
MG428
Perhaps other than better zoom modes, as someone who uses his BDP-83 primarily with 1080p material via non-source direct and bitstreaming to the AVR, I had splurged 42% more money on BDP-83, right? Because;
- as to the PQ, there seems to be no difference between BDP-80 and BDP-83, or even other BD players for that matter that can output 1080p; and
- as to the AQ, since, assuming that my Denon AVR-988 has a better DAC than that of BDP-83, I bitstream to my AVR.
As a matter of fact, I do not benefit from any AQ features of BDP-83 at all, and in terms of PQ, even if I benefit from the ABT processor of BDP-83, it seems that it does not make any difference with 1080p material.
I wish there was a downgrade option...
When did you buy the BDP-83? If it was less than 30 days ago, then you can still return it to OPPO.
If the only reason you ever bought the BDP-83 was for watching only Blu-ray movies at 1080p, then that wasn't the wisest chioce to begin with.
If you use the player to also watch upconverted dvds on a screen larger the 37-42" or more, then the BDP-83 will have better PQ anyway.
Instead of wondering how much money you may have wasted, you should be happy in knowing that you own a player that other OEMs believe is worth 7 times more than what you paid.
It's a great player, but you shouldn't need anyone here to tell you that.
