So I've got a pair of TD15X's, a pair of B&C DE500's, and a pair of QSC waveguides on the way all set to arrive next week. I'm not dead set on the XO but am thinking somewhere between 900hz and 1.2kHz. I'm using a DCX2496 for crossover so can tweak that quite a bit. I'm trying to design the enclosure now. I'm thinking of going ported even though my IB sub is good up to 120hz. I've tried to eye up how big of an enclosure I can put up with and I think 20" wide x 18" deep x 48" high looks pretty reasonable. I could stretch any of the dimensions a bit but don't want to stretch them all too much. That gives me about 225l (or 8cuft) to work with. Where I'm having trouble is juggling enclosure size, port air velocity, and port resonances. I found an old thread where John recommends 140l tuned to 27hz with a 3"x16" slot port 26" long. I modeled this up but found that that puts the first port resonance really low - well within the passband the TD15X will be playing in (in fact the 2nd, 3rd, and 4th resonances are probably in the passband with that setup too). I have some 4" PVC pipe in the garage so was looking at using that tuned to around 30-35hz. If I only use one port the 1st port resonance is just out of my passband but then the air velocity gets too high. If i move to dual 4" ports the air velocity is under control but then the port resonance is right back in my passband again! If I make the box bigger the port gets shorter and therefore resonance goes up but I can't go much bigger than this. Also if I just tune higher I end up with a big bump in the FR at tuning.
Any thoughts? Am I better off just sealing it? I just hate to waste the extra low end (and reduced THD on the low end) that ported would add for this build. The more I think about it the more I think I should just seal it up...
I should add I'll be powering with a 100W/ch Onkyo receiver for now but will likely be upgrading to a pair of pro amps when $ becomes available (so I've been modeling sending it 400W or so to see the "worst" case for chuffing).
Here's the T/S params:
TD15X- 8ohm
Fs 23.2 Hz
Qms 3.82
Qes 0.31
Qts 0.28
Vas 467 Liters
Cms 0.45 mm/N
Mms 105 grams
Sd 855 cm2
Rms 4.0 Kg/S
Bl 16.7 T/m
Re 5.6 ohms
Z 8 ohms
Le 0.3 mH
Pe (max) 500 Watts
Pe (transient) 1000 Watts
"no" 1.82 %
1WSpl 94.8 dB
Linear Xmax 14 mm (peak)
Mech Xsus 20 mm (peak)
TD15X- 8ohm
Fs 23.2 Hz
Qms 3.82
Qes 0.31
Qts 0.28
Vas 467 Liters
Cms 0.45 mm/N
Mms 105 grams
Sd 855 cm2
Rms 4.0 Kg/S
Bl 16.7 T/m
Re 5.6 ohms
Z 8 ohms
Le 0.3 mH
Pe (max) 500 Watts
"no" 1.82 %
1WSpl 94.8 dB
