AVS › AVS Forum › Audio › Speakers › Is this a good deal for Klipsch Speakers
post #1 of 3
Hi I am getting the following Klipsch Reference Series Speakers for $400 total. They are about 7 yrs old. Is this a good price for the set. Work well according to the seller. I will go test it out tomorrow.
Two towers (RF-3), the center channel (RC-3)
RF3 --> http://www.klipsch.com/na-en/products/rf-3-overview/
http://www.audioreview.com/mfr/klips...6_1594crx.aspx
RC-3 --> http://www.klipsch.com/na-en/products/rc-3-overview/
http://www.audioreview.com/mfr/klips...5_2743crx.aspx
post #2 of 3
If they are in good shape, that's a good price.
post #3 of 3
Also one more question. I am also looking for a new sub. I can get a new BIC F12 new for $182 or get a used Klipsch RW10d used for $125. Which sub is a better deal. The Klipsch specs says it goes down to 28-120 hz. The BIC F12 has a freq respone from 25-200hz.
Links to both
Bic F12 --> http://www.shopblt.com/cgi-bin/shop/...er_id=!ORDERID!
Klipsch W-10d - http://www.klipsch.com/na-en/product...pecifications/
Please advise. Need to make a decision within 12 hrs. Thanks.
  Back to Forum: Speakers
