So here goes... yet another THT build thread... The parts were ordered earlier in the week, got the wood last night, gathered tools and such as well.
Got the driver today and other misc parts... and began cutting. My progress was slow and inaccurate until I got a system down. I'll have to go back over the first half of the wood and measure and trim as necessary, no big deal since I cut everything slightly long (It's been a while). If it's short, I'll let the PL Premium fill the gaps...no error should be greater than 1/8" if my calculations are correct.
I can't even begin to explain how massive this driver is. I set it up while I was cutting and ran a 30hz sine wave through it at 10v or so to give it a little stretching, but the amp was getting a workout more than the driver was so I only let it run half the day for now. Tomorrow I'll remeasure and trim where necessary, then start the build.
My 10" Bic shakes windows and doors and walls...I can only imagine what this will do. Which is good, I won't need a killer amp, so I don't have to worry about going with a EP2500 or anything, this simply doesn't require it. I'll make an amp decision next week and order it... Until then once this is finished I'll just run it on the Bic's amp. Anywho, I'm tired, and I have to go to work in an hour...more updates tomorrow.
The dayton sitting on top of my current Bic V1020...
The 15" dayton next to the 10" Bic driver
My phone dwarfed by the driver
The workspace all cleaned up, with the wood laying flat, some with weights on them, in an attempt to avoid warping
. Keep it up.
