Originally Posted by
ehgz1
I would go with the Vizio...the LED's should make for much better black levels than the Sony.
Thanks- Now I just have to weigh the the thought of spending an extra $349
I talked to a Sales person at Costco who said he'd pick the Sony over the Vizio.
He said the 120hz Motion-Flow is comparable to the 240hz (?)
But LED seems to be the future of quality television.
[b][b]Here are both tech specs:
Between these two:
Sony Bravia KDL-46VL150 46” Motionflow™ 120Hz 1080p LCD HDTV $799.99
The Sony Bravia KDL-46VL150 46” Motionflow™ 120Hz 1080p LCD HDTV is taking high definition to an entirely new level. It’s a high definition world and the best high definition resolution this brave new world offers is 1080p; that’s why Sony has more Full HD 1080p HDTVs than ever before.
Features:
Screen Size (measured diagonally): 46"
Aspect Ratio: 16:9
Resolution: 1920 x 1080
Contrast Ratio: 5,000:1
Dynamic Contrast Ratio: 70,000:1
Viewing Angle: 178º x 178º
Motionflow™ Technology: Motionflow™ 120Hz
Video Processing: Bravia Engine 2™ Technology
CineMotion® Reverse 3:2 Pulldown Technology
Tuner: NTSC/ATSC/QAM
BRAVIA® Sync™
USB Application(s): Photo Viewer (JPEG)
Game Mode
3D Comb Filter
24p True Cinema™ Technology
Advanced Contrast Enhancer (ACE)
VESA® Hole Pitch: 300x300 M6
Energy Star® compliant: Exceeds Energy Star version 3.0
Dimensions (WxHxD): 43” x 29.4” x 13” (w/ stand), 43” x 29.4” x 3.4”
Weight: 53 lbs (w/ stand), 45.6 lbs (w/ out stand)
Audio:
Speakers: 20W (10W x2)
Digital Amplifier
Auto SAP
Auto Mute (on no signal)
Steady Sound® Automatic Volume Control
Audio Out: Fixed
Stereo System: MTS
Dolby®: Dolby® Digital (for broadcasting)
Alternate Audio (Digital)
SRS®:SRS® TruSurround XT®
Sound Mode: Dynamic, Standard, Clear Voice
Inputs/ Outputs:
HDMI™ x4 (3 Rear/1 Side)
Component Video x2 (Rear)
S-Video x1 (Side)
Composite Video x2 (1 Side/1 Rear)
Digital Audio x1 (Rear)
RF Connection x1 (Rear)
Analog Audio Input x5 (2 Side/3 Rear)
Audio Out x1 (Rear)
PC In (D-Sub) + Audio In (Stereo Mini) x1 (Rear)
USB 2.0 x1 (Side)
VIZIO Class XVT Series TruLED XVT472SV 47-Inch 240 Hz sps LCD HDTV $1149.99
VIZIO’S 47” TruLED™ HDTV LCD continues to break the mold of traditional HDTVs, delivering the latest technologies for superior picture quality and sound! This direct type, backlit HDTV is comprised of 640 LEDs divided into 80 control blocks and utilities Smart Dimming™ to intelligently control these blocks, turning them on and completely off based on the content you’re watching. This cutting edge technology stops light leakage enabling you to achieve REAL 2,000,000:1 contrast ratio for rich, dark scenes delivering an experience that will blow you away. The Extreme VIZIO Technology series epitomizes what HDTV should be!
Features:
Costco extends manufacturers warranty to 2 years
Screen Size: 47” Diagonal (46.96" viewable)
A 47" panel is 62% larger in viewable screen surface than a 37" panel
Aspect Ratio: 16:9
Dynamic Contrast Ratio: 1,400:1
Dynamic Contrast Ratio: 2,000,000:1
Brightness: 500 cd/m2
Response Time: 5 ms
Viewing Angles (HxV): 178˚x178˚
HDTV Compatibility: 480i/480p//720p/1080i/1080p
LED: Direct Type LED Backlight Technology with Smart Dimming - 640 LEDs (80 control Blocks)
Refresh Rate: 240Hz
3D Comb Filter
Progressive Scan
Picture in Picture
Smooth Motion
Dimensions (WxHxD):43.9” x 29.7” x 10” (w/stand) 43.9” x 28.1” x 4” (w/out stand)
Weight: 51.8lbs (w/stand) 46.5lbs (w/out stand)
Audio:
Speakers: 2 x 15W
Input/Output:
HDMI x4
Component Video x 1
S-Video Input x 1
Composite Video Input x 1
Stereo Audio out x 1
SPDIF x 1
RGB Input x 1
