After trying several methods and ways of trying to get all 3 audio use cases ( high end 2 channel, multichannel hometheater, and streaming high res digital music) to play nice without getting "too" complicated (key word "too"
), I finally got my system to sound great in all three areas without the need of tons of switches and Crossovers and the like.
So, first things first: Please see the attached diagram of my system's audio connections.
A few comments and guides:
1) Any good Preamp with Unity gain (ie, HT-bypass) functionality will be needed. Without this, you cannot integrate the preamp to the pre/pro well.
2) Your Pre/Pro needs to have a "extended bass" or "redundant bass" functionality, in which bass is routed to both the subs as well as the mains when set as full range.
3) Any good DAC with either USB or Firewire will work, but keep in mind that most DACs with USB will only support 44-48Khz sampling, and thus, you will not be able to pass high resolution 192khz lossless music thru without downsampling.
4) when using wireless for the high res music via laptop to DAC, you need not only a good G (or better yet, N ) router, but also a laptop that can handle the information and process it out to the port rapidly.... I've had some problems with pentium based laptops running XP, but no issues with Windows 7 at all.
5) low res streaming (MP3's, etc) can be done to the laptop as well, obviously. I just happen to have the PS3 there and love the user interface...it serves as my media center (pics, movies, netflix, mp3's). You can use the HTPC, Xbox, Popcorn hour, or any similar device.
6) the main key is that to use high resolution 2 channel audio to the preamp, and still be able to engage the subwoofers, you will need to send the data to both the pre/pro AND the preamp. If you do not need/want the subwoofers engaged, simply connecting the data transport to the preamp will suffice.
there will hopefully be tons more discussion and questions, but I hope this helps initiate some of them, and also helps those who want it all without major complications of switches and crossovers, etc.
ps- if the attachment doesn't show up well, you can use my sig's link for the audio connection schematic for a bigger version of the pic.
), I finally got my system to sound great in all three areas without the need of tons of switches and Crossovers and the like.So, first things first: Please see the attached diagram of my system's audio connections.
