Originally Posted by
joe citizen
What video input are you using? Try composite, component and HDMI inputs and see if you have pixelation with all three. Also make sure you have the latest firmware.
I have heard that component will not output at 1080p....
I specifically bought this unit for playing 1080p mkv files alone and I am thoroughly disappointed with the results.
Also there is another glitch with the audio settings...as the unit always outputs audio through hdmi even though I set it not to.
Yet another problem is that each time I plug the unit into my pc...I cannot check whether it needs to be defragmented due to a CHKDSK error....which I have ran numerous times and yet it keeps on happening after each boot of the HV335T.
This is also happening with an 8Gb usb drive when I plug into the pc it says chkdsk needs to run....yet when it has finished it shows there are no errors on the drive.
In the future my 1Tb internal drive will undoubtadely need defragged but if this unit keeps causing this chkdsk problem, it will take hours to run on the drive before I would be able to defrag. This is unacceptable.
What is going on?
