Hi all
Here is my 2.40 Mod install.img for HV335T, again not much change from before, just remove two broken link in “More IMS”, replaced VTuner icon, I don’t see any different from 2.37 but it is some change in Dvdplayer from Argosy.
Also here is the program “ make-squashfs” for who want to make your own Mod for install.img, first unrar “make-squashfs.rar” to a folder then copy install.img to same folder and double kick “open-unsquashfs.bat” soon later you have two more folder the “install” and “squashfs-root” create by software then use “notepad++” to edit the xml files in “squashfs-root\usr\local\bin” and rss file in scripts folder, after complete change double kick “make-squashfs.bat” soon later a new install.img will create by software now you can put new install.img file to usb pen drive test in your box, if the new Mod cause your box 'bricked' you can follow my post at post#466 to unbrick the box with good firmware .
My firmware already telnet enable but if you have hard drive installed you need to enable "samba" and "bit tor ent" in setup before can use telnet.
use this firmware at your own risk.
http://www.filefactory.com/file/8slk8h367nf/n/install_img
http://www.filefactory.com/file/3i8t7xsisdm9/n/make-squashfs_rar
Sorry for my limited English, good luck.
Edited by nymsc - 7/26/12 at 6:38pm
