AVS › AVS Forum › A/V Control & Automation › Remote Control Area › How to reprogramming buttons on Comcast Remote?
post #1 of 20
My parents have comcast. they have a scientific atlanta explorer 8300 hdc dvr box. it has a silver remote with a red "ok/select" button. They also have a charcoal grey remote that looks identical except for the color. It also has the red "ok/select" button.
They want to use both remotes to control the tv & cable box. That way mom has a remote and dad has a remote.
The issue we are having is that almost all of the buttons work except for the "A" (yellow triangle) button and the "C" (red circle) button. When we use the remote to set up a recording and the last thing you need to do is press the "A" button to save it or the "C" button to cancel and right now when we press these buttons nothing happens.
So, the question is: How do I "program" these buttons to function as they should?
Thanks in advance for any helpful replies.
post #2 of 20
Well I know the following will work for the Silver comcast remote. These are the instruction to add the 30 second skip to HD Zoom button so you can skip commercials on recorded shows.
"The following instructions will re-program the "HD Zoom" button on the remote control to function as a "30 second fast forward" button. Works perfect for skipping through commercials. It will function when playing programs recorded on the DVR & also when playing a buffered program.
1) Press the "Cable" button at the top of the remote to put it into Cable Box control mode.
2) Press and hold the "Setup" button until the "Cable" button blinks twice.
3) Type in the code 994. The "Cable" button will blink twice.
4) Press (do not hold) the "Setup" button.
5) Type in the code 00173 (for 30 second Skip).
6) Press the "HD Zoom" button to map the skip or swap function to it.
7) You're done."
P.S. you can also select whatever button you want to assign for the most part.
The following are all the codes for all the commands available. You have to follow the same process as above but you would punch the code for the command you want i.e. A is 077 but you will likely have to punch in 00077.
Advanced Codes for cbl_0476
General Instruments Cable Box
Cable Converters --
0476 077 A (Diamond) 207 Fast Forward 243 Parental Lock 046 Record
237 B 115 G 177 M 242 Reserved 1
240 Browse 111 H 173 N 211 Reserved 2
114 C 048 Help (*) 034 O 238 Reserved 3
236 Cancel 113 I 211 Out Channel 208 Reserved 4
110 D 044 Info 210 P/F 204 Reserved 5
174 Day Minus 109 J 172 Page Down 209 Reverse
178 Day Plus 179 K 176 Page Up 241 A / Theme
112 E 175 L 205 Pause
108 F 239 List 081 PPV
CABLE CONVERTER.
018 0...............0 014 1...............1
016 2...............2 012 3...............3
019 4...............4 015 5...............5
017 6...............6 013 7...............7
146 8...............8 142 9...............9
147 CHANNEL DOWN....Channel Down 140 CHANNEL UP......Channel Up
047 DOWN............Down 080 CLEAR...........Exit
079 SURROUND........Fav Ch 050 PROGRAM.........Guide
076 RECALL..........Last Channel 049 LEFT............Left
206 MENU............Menu 082 ENTER...........Music
141 MUTE............Mute 144 POWER...........Power(CATV)
045 RIGHT...........Right 078 SELECT..........Select
083 TV/VCR..........Switch A/B 051 UP..............Up
145 VOLUME DOWN.....Volume Down 143 VOLUME UP.......Volume Up
PVR Functions...
178 Play
205 Pause
209 Rewind
207 Fast Forward
174 Stop
046 Record
173 Skip
179 Replay
175 DVR
210 PPV
208 OND
083 A/B
177 Live (DVR)
236 Swap (dual tuner DVR)
Again i know these work for the silver remotes shown on this link
http://www.comcast.com/corporate/cus...t/remotes.html
as far as the other I cant say for sure.
post #3 of 20
The above post with Cable code 0476 is correct for Motorola set top boxes. For Scientific Atlanta, you need a different set of Extended Function Codes (and a different setup code,too--but you've already got that under control).
Go to http://hifi-remote.com/jp1/lookup/ and choose Device Search. Use Cable 1877 or 0877, and select Comcast 1067BX3, JP.1.3. Click Search, and on the next page click on the link labeled EFC at the far right of the page. Look for the button name, get the 3 digit EFC, and when using the 994 command instructions in the above post, prepend 00 to each 3 digit EFC.
For example find Page + on the web page, notice the EFC is 057, and in the 994 procedure enter 00057.
post #4 of 20
My fault, I didn't realize that 3fingeredglove. I have becomed so accustomed to Moto boxes I didn't even thinkg about that.
Here are the codes I found from the instructions above.
EFC's Used on Various Versions of this Device
The efc's listed below can be used as a starting point for an upgrade. Often more than one EFC will be listed for a function. You'll need to test these to see which one works with your device.
Device: Cable / 1877 Brands
Protocol: Panasonic (old);
Devices: 27; , 28 ; 30 ; ;
Pid: 0000 ;
Fixed: 90 E0 C0;
Function EFC
num 0 214
num 1 090
num 2 086
num 3 088
num 4 084
num 5 091
num 6 087
num 7 089
num 8 085
num 9 218
Volume + 250
Volume - 246
Mute 248
CH+ 215
CH- 217
Power 021
Arrow_Down 148
Arrow_Left 020
Arrow_Right 027
Arrow_Up 024
Guide 117
Guide 025
Input/Source 151
Format 16:9 216
Format 16:9 187
OK/Select 155
Select 155
Last/Prev Ch 153
FAV 213
Sleep 249
EXIT 123
TV/STB 058
TV/Video 151
Info/Display 154
ENTER 054
ENTER 155
ENTER 068
ENTER 184
Enter[#] 184
[*] 149
PIP On/Off 180
PIP Move 183
PIP Swap 187
PIP Ch+ 121
PIP Ch- 181
PIP Replay 118
Play 052
Stop 059
Pause 023
Rewind 245
Rewind 118
FFWD 212
FFWD 122
FWD 122
Record 055
Skip + 057
Skip + 122
Skip + 121
Skip - 181
Skip - 053
Skip - 245
Green 191
Red 054
Yellow 117
A 117
B 058
C 054
Audio 249
ByPass 151
CC 249
CC 183
CC 189
DVR 249
Day + 157
Day - 098
HD_ZOOM 068
HD_ZOOM 184
Help 119
List 249
Live 216
Menu 185
Menu 249
Menu 182
MyDVR 249
On Demand 149
Page + 057
Page - 053
Quick Skip 122
Replay 245
Replay 216
Settings 182
Settings 185
Signal 245
View TV 216
Device: Cable / 0877 Brands
Devices: 27; , ; ; ;
Pid: 0000 ;
Fixed: 90 00 00;
Function EFC
num 0 214
num 1 090
num 2 086
num 3 088
num 4 084
num 5 091
num 6 087
num 7 089
num 8 085
num 9 218
Volume + 250
Volume - 246
Mute 248
CH+ 215
CH- 217
Power 021
Arrow_Down 148
Arrow_Left 020
Arrow_Right 027
Arrow_Up 024
Guide 117
Guide 025
Input/Source 151
Format 16:9 119
OK/Select 155
Select 155
Last/Prev Ch 153
FAV 213
EXIT 123
TV/STB 058
TV/Video 151
Info/Display 154
ENTER 054
ENTER 184
Enter[#] 184
[*] 149
Play 052
Stop 059
Pause 023
Rewind 053
Rewind 118
FFWD 057
FFWD 122
FWD 122
Record 055
Skip + 151
Skip + 057
Skip - 053
Red 054
Yellow 117
A 117
B 058
C 054
ByPass 151
Clear 123
DVD 213
Day + 054
Day + 022
Day - 058
Day - 026
HD_ZOOM 184
Help 119
Help 149
Help 117
Menu 152
Menu 182
Menu 155
Page + 057
Page - 053
Settings 182
Settings 152
post #5 of 20
Oman & 3fingered,
Got it working as desired.
Thanks!!!
Jim
post #6 of 20
Hi guys, Very new to this...just struggled to get registered on forum so that gives you a clue. I am trying to program a Scientific America comcast box with the silver remote for 30 sec. fast forward skp. I read your posts--Oman-- BUT I am struggling to figure it out. Can you be real simple for me...stepwise so a grandmother of 12 can understand it? Previously I programmed a comcast motorola remote to do 30 second skip forward so there is some hope. The cable box is an 8300. I am pretty certain (after looking at the pictures) that I have a silver universal remote. THANKS
post #7 of 20
sidwid,
I've searched through the files at hifi-remote.com and at remotecentral.com. None of the files show a function similar to the 30 second skip available on Motorola boxes.
However, the 6 files that I found all appear to be based on signals learned from the original remote, and the cable companies don't like to encourage skipping past commercials, so a skip probably wouldn't be in the original remote.
If you really want to try to find a skip function, ypu can do an exhaustive search of the possible codes, using the Comcast remote. To do this, you'd setup the SA box playing a recorded show--so that you'll be able to notice if you do successfully send a skip command.
Then, you'll systematically try every function number between 00000 and 00255. To try any function number, make sure that you've pressed CBL, then...
1) Press Setup
2) Enter the 5 digit function number.
So it goes Press Setup
Enter 00000 (while pointing the remote at the box. The IR signal will be sent when you press the 5th digit. See if the box responds in some way.
Then, Press Setup
Enter 00001
And over and over again until you reach 00255.
Maybe one of those function numbers will be the skip command you're looking for. You can probably do 10 per minute, so it will take a half hour. Or you could spend a little more time and write down the result of each function number. Maybe you'll find dome other goodies.
post #8 of 20
I have an older silver comcast remote that does work for the 30 second skip forward, but my dog ate it so I am trying to set up the new remote I got. it is the darker silver. everything seems to be the same except the lock button has an orange triangle with an A in it, instead of a yellow one. I have tried code 00173 but it will not work. I even tried going through all of the codes 00000-00255. I'm sure I probably missed one or two. Is this remote any different? It says UM-3 /R6
also the white sticker inside saysrc1475507/03b 16003
cifa no 27634
post #9 of 20
cifa no 27634
Forgot to give cable box. Motorola RNG200N
post #10 of 20
Sorry, that remote is very different. None of the codes or methods in this thread will work on it. In fact it's impossible to add any commands to that one. If you pick up a remote like your old one from your cable company or buy one from ebay (they tend to run under $8 shipped), then you can add any and all commands per this thread. Just search for comcast remote. A retail RCA RCRP05B will also work. It runs about $15 most places. If you strike out, I can sell you one as well. I have a ton of those I need to get rid of. Just PM me.
post #11 of 20
mdavej,
What remote do you think grimacedface has? The UN3-R6 refers to a AA battery. I suspect that he has one of the newer Comcast 1067BX3s, but I'd like to hear for sure.
grimaceface,
Anyway, the RNG200 uses the XMP IR protocol. If the the "new" remote is a Comcast, the needed setup code is 01982, not 00476/01376. This setup code needs 5 digit EFCs and 00173 is certain to not work. Here's list of the known EFCs for the RNG series. Unfortunately, we don't have one for 30 second skip. If you want to search, I can generate the set of all 256 possibilities.
Tell us if this is a Comcast-supplied remote, or if it blinked twice when you entered 994.
post #12 of 20
I ended up just going to comcrap and getting two lighter silver remotes. Thank you for checking on me though.
post #13 of 20
Originally Posted by 3FingeredGlove View Post
mdavej,
LOL. Saw the U, didn't recognize the rest and assumed URC. Never dreamed it was the battery.
post #14 of 20
How does one lock the TV/VCR Input button to the Aux function?
Ie when I'm in Cable mode, I want a TV/VCR press to change the input on the AUX ie receiver.
I really don't need to switch functions if Vol is locked to TV (controls receiver vol) CH is locked to cable and input is locked to AUX.
Any help?
post #15 of 20
1) Press and hold the SETUP button until the red LED flashes twice, then RELEASE.
2) Tap 9 - 9 - 4. (2 blinks)
3) Tap AUX
4) Tap TV/VCR
5) Tap Cable
6) Tap TV/VCR
Should get 2 blinks
http://www.hifi-remote.com/wiki/index.php?title=Manual_Programming_-_9xx_Commands
post #16 of 20
Not getting 2 blinks, getting the 1 long.
Instead to get it to work I did:
PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
TAP 9 - 9 - 4.
TAP the "from" DEVICE button (eg, TV)
TAP the SETUP button
TYPE the 3 or 5 digit EFC code (aka "advanced code)
TAP the "to" DEVICE button (eg, VCR)
TAP the "to" regular button (eg, VOL+) - two Blinks
So:
TAP 9 - 9 - 4.
TAP the AUX button
TYPE the 00246
TAP the CABLE button
TAP the TV/VC button and get two blinks
post #17 of 20
Hey my Onkyo went out, so I got a Denon AVR-1613. Can you help me with codes to remap some keys on Comcrap remote? I'm wanting to make the number keys switch inputs. Currently only 2 work. Thanks in advance.
P.S. I'm also wondering if the Denon remote is a universal remote, because I'm not seeing anything about programming it.
post #18 of 20
Yeah my bad lol.
post #19 of 20
Using the Advance Search function on Comcast Denon, and the search restricted to Remote Control Area brings up a thread on discrete inputs. Have you tried those EFCs?
post #20 of 20
I hope it's OK to ask this on an old thread...
If I want to program a "skip ahead" button on my Harmony Remote, will I have to "learn" that command from my Comcast remote which I have programmed for the skip function?
  Back to Forum: Remote Control Area
