Hey guys, im new in here.
I have 2 problems here:
1.:
I have a problem with my movies on my external harddrives.
I have 4x 1TB WD MyBooks E edition.
I hooked them up to my NetGear WNDR3700.
It shows up fine on my 3D bluray player, and it lists them all fine.
But some how it doesnt want to play my MKV files.
Avi and mpeg files are fine, but says the files are not supported when i try play the mkv files.
2.:
I also tried the "server" option, with samsungs software, they play fine though there.
But, the software is poor. I have so many movies it times out or something.
It just stops making database files along the way.
Tryed adding them slow, like a small bunch at a time, still cant seam to add em all. Like the player has a maximum amount of files it can add.
Anyone have the same problem, or does anyone know what i can do?
Ofcause, i want problem 1 solved before 2, as its the best option for me.
