AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Netflix - too much rebuffering on Sony Bravia Engine 3 TVs (W5100/Z5100/XBR9)
post #1 of 63
So I have a 46W5100 which has the same Bravia Engine 3 as the Z5100 and the XBR9. I've noticed that since I loaded the latest firmware aa151, there's been a lot of Netflix rebuffering when watching HD movies. It happens during SD movies as well, though not as much.
Here's what I find.
1) Watch for 10-15 mins w/o problems
2) Rebuffers once, watch for < 1 min, rebuffers again and repeats
3) Quit the Netflix app, go back to TV channel/input
4) Relaunch Netflix app and movie and repeat steps 1-4.
With previous firmwares, I was able to watch HD movies on my W5100 w/o all this rebuffering...infact I don't remember it ever rebuffering.
It's really annoying because once step 2 happens, it isn't watchable.
You could blame my network, but my PS3 is hooked to the same network (wirelessly) and it doesn't suffer from any of this rebuffering crap when watching Netflix HD movies. Yes I could always use my PS3, but it isn't always in the living room as sometimes I might be playing a game while wife is watching the TV.
Is there anyway around this constant rebuffering?
post #2 of 63
yeah complain to sony so they fix it in a firmware update because obviously it worked fine before you updated your FW
in the mean time at least you have let other owners know that they should not update their FW unless they don't care about netflix
post #3 of 63
I actually get better Netflix performance with the latest ethernet based firmware upgrade (ver. 151). It's still rebuffers, particularly with HD content, but it's improved from before.
That said, the tv is still not nearly as good as my 2 year old Samsung 2550 bluray player for Netflix streaming, so hopefully future firmware upgrades will improve the tv even further.
post #4 of 63
Not too many respones here so I'm wondering if others are not having problems. I took some additional steps last night.
1) My TV was at aa151, but I thought maybe the latest on the website, aa153 might be better.
2) Turned off TV and unplugged.
3) Plugged in USB flash drive with aa153 on it
4) Plugged tv back in and turned it on.
5) After it updated, I tried loading Netflix and started watching some HD content. It did rebuffer once, but the constant rebuffering seemed to not occur. Can't tell whether it was just a coincidence or not. I will try again tonight.
post #5 of 63
I have the same problem with the Samsung 4600 blue Ray player hooked up to a Hitachi 55 in plasma. I don't think it has anything to do with the TV. I am also not sure sure if it's the Blue Ray player or the netflix stream itself.
post #6 of 63
Ok so as I stated in my last post, I've experimented with the latest firmware from the sony website (aa153) by running Netflix HD movies during prime time (7pm-10pm). On Monday night, I was able to watch for about 42 mins w/o problems, but then around 8pm, things got ugly with constant rebuffering. I quit the app, restarted it and it was better but still flakey. I then tried to watch a different HD movie, and it was really bad...pretty much unwatchable. I then waited an hour, and things got better.
All this time, watching anything on the PS3 works flawlessly w/o any rebuffering.
Last night, I watch a HD show on Netflix for about 1 hour w/o problems, but I wanted to watch Live TV at 8pm, so I stopped watching and resumed at 9pm. Things worked w/o problems.
I'm not sure what throws the thing into a funk where it gets into that constant rebuffering mode. It ain't the network though because I plugged into the router with my laptop and got 11mbps down and 4 mbps up.
post #7 of 63
i'd suspect the network since it's a network stream... guessing you're wired in and not wireless
post #8 of 63
Not the network...as I said, did speed tests and got 11mbps down and 4mbps up. Also, different device (PS3), using same network and same Netflix service and HD movies (Always) performs flawlessly irregardless of it being prime time or not. And the PS3 can be wired or wirelessly and even when I use it wirelessly I've not had issues. So it is definitely the way the Netflix app is setup on the Sony TVs, or maybe it hits some intermediate server that the PS3 doesn't or something....don't know what the deal is.
post #9 of 63
Usually those streaming devices will prefetch data before they actually play the stream. So my best guess is that since ps3 has the built-in hard drive it may be able to prefetch and save more data than the TV does, which results in a noninterupted viewing experience. Just my 2 cents.
post #10 of 63
I have the same problem with my Panasonic. I figured it was a problem with the connection speed rather than the TV.
post #11 of 63
Here's the thing though...the PS3 will start playing the movie way faster than the TV, so it's not like it is sitting there prefecthing/buffering before the movie starts more than the TV. The TV takes much longer and does appear to do more prefetching before the start of the movie, so in reality, the TV should perform better.
Also, once it gets in the constant rebuffering mode, quitting the netflix app on the tv and then going back shouldn't really help if the network is the issue.
post #12 of 63
Watched an HD documentary last night at 8:00pm EST and not once did it rebuffer. I had previously watched a few SD videos without a hitch.
I have my 52XBR9 networked via ethernet over powerline.
Not sure about the PS3, but the Xbox360 will adjust the video quality to match your network speed since it is a computer and your TV is not. Plus the TV only has a small amount of memory which is not enough to buffer any video unlike your PS3 and Xbox.
post #13 of 63
I didn't have problems last night either, but did on Monday night and over the weekend.
post #14 of 63
I've given up and dragged the Roku box to the living room. I still have some rebuffering on the Roku watching HD but no where near what the Sony KDL46W5100 does.
post #15 of 63
If you're having issues and you know you have a fast or fast enough network, go to http://internet.sony.tv, log in, click on 'Content and Support Issues' and file a complaint. Be as specific as possible and make sure you point out that it isn't your network, because that is the first thing that people think of as the problem.
post #16 of 63
I had actually done this and they replied "forwarded to Netflix Administrator". Almost a week later I replied for a status update, they (Sony) actually said to call Sony support and gave a phone number. I have not called yet (severe cold).
However, you can go onto Netflix site and report that you had pauses on the watch now streams, which I have done on just about every video we've watched. I haven't received a response from Netflix for doing that, however, it seems to have gotten somewhat better.
post #17 of 63
It seems that this is happening to many of us with all different kinds of TVs and Blue Ray players/setups ect.. I must conclude that this is a Netflix problem.I have this problem on a regular basis. Sometimes it will only rebuffer once early on and play the rest of the movie fine. Sometimes it's nothing but rebuffering till I give up.
post #18 of 63
What device did u have the issue on? Is it a sony bravia tv?
This morning around 830am est, I launched the netflix app on my sony w5100 soon after it booted up and I noticed that not all the icons of movies in my queue were loading. It seemed they were loading slowly. I then tried to watch an SD tv show episode and it kept rebuffering...unwatchable. I quit the netflix app, reloaded it and all was fine. I think they definitely messed something up with the netflix app in the aa151/aa153 firmware.
post #19 of 63
Never was able to get the streaming to be of any use. Netflix streaming on the W5100 is a complete waste...thats why I don't even bother anymore. YouTube is actually is much better user experience. All the other streaming channels are a joke...yea, really want to watch a few min clips of TV shows.
post #20 of 63
Mu setup is a 55 in. Hitachi Plasma with a Samsung 4600 Blue Ray player.Hooked up to cable internet service going through a new WRN2000 Netgear router,wireless. I had another router hooked up before this one with the same problem. I can sit in front of the TV with a laptop hooked up to the same router but the laptop still has a good internet connection while the Netflix is rebuffing.
I rarely get to watch a movie all the way through without it rebuffing. It's a pain and I think the problem is on Neflix' end.I am almost 100% positive that this has nothing to do with your TV.
post #21 of 63
I hear you, but I never had these problems until the latest firmware. Now, there are times when it works great and there are times where it is unwatchable...typically it is somewhere in between.
I remember reading the firmware notes for this latest version talking about how they improved netflix performance and I wondered what it was that needed improvement. Alas, this firmware seems to have created the problem that it claimed to solve. I guess it is possible that I just happened to never experience the problem with the older firmwares.
post #22 of 63
I've been experiencing excessive buffering on my 5100 as well. Additionally, in the 2 weeks that I've had the TV, while watching movies on Netflix Watch Instantly, the TV has restarted by itself. There's a popping sound in the audio then the screen goes black and the TV restarts.
At first I thought it was something with the power, but after doing some reading, I don't think so. Also, this has only happened when watching Netflix Instant movies.
Has anyone else experienced this?
I called Sony and they are sending me a flash drive with a firmware upgrade. I doubt that will do much good because as soon as I installed the TV, I downloaded the latest firmware.
post #23 of 63
Just an update: I've not had as many issues with rebuffering as of late. It could be that I've been watching more SD content than HD, but I don't know. I did get this email from Netflix a couple of days ago though:
Dear Russell,
Recently, you may have had trouble instantly watching movies or TV episodes via your Netflix Ready Device due to technical issues.
We are sorry for the inconvenience this may have caused. If you were unable to instantly watch a movie or TV episode via your Netflix Ready Device, click on this account specific link in the next 7 days to apply your 3% credit to your next billing statement for your 2 DVDs out at-a-time (Unlimited) plan. Credit can only be applied once.
Again, we apologize for any inconvenience, and thank you for your understanding. If you need further assistance, please call us at 1-866-923-0898.
-The Netflix Team
This is probably because I complained through the MyEssentials (internet.sony.tv) site.
For those who were having issues with the rebuffering, has it been better as of late?
post #24 of 63
Kinda funny you should bring this up because I watched 2 movies yesterday without a hiccup. I firmly believe that the problem is on Netflix' end. I guess we should keep an eye on this thread and see if everyone is having the same problems at the same times?
post #25 of 63
Were they HD movies? I rarely have any issues with non-hd movies. I watched 'Sky Captain and the World of Tomorrow' last night and about half way through, it rebuffered and the audio was all out of sync, it promptly rebuffered again, but had the same problem. I had to quit the movie and the app and restart it for it to work properly.
post #26 of 63
this is a real stupid question, so bear with me - but i just saw something similar happen here at work which got me thinking.
but could it just be due to speed / duplex settings on the hub/switch/router port that your tv is connected to?
post #27 of 63
No, I speed tested several times with a laptop hooked into it and the speed was really good. I also have my PS3 hooked into it and I've had no speed issues.
post #28 of 63
yeah but those 2 devices could be handling the auto-negotiation better than the tv... how about locking down the speed and duplex? and then connecting to the management interface for the router/firewall/switch and seeing if you're getting packet drops/errors which could indicate negotiation issues..
post #29 of 63
Thanks for the suggestions...I doubt that this is causing any issue, but I'll look on the router's management screen and see if there's a way to lock it down. What should I lock it down to? 100mbps full?
I don't recall seeing any dropped packets or errors before.
post #30 of 63
it's the only thing i can think of aside from a tv-specific issue...
if it shows you the statistics on the port, see if it shows any errors...
if it does - then it's more clear cut.
and yes, 100 full is what i would try (ideally, should be having that on both sides, but i doubt the tv allows you to configure that...)
