I am searching for a projector and I think I have narrowed it down to Optoma HD20. My budget is under $1300.
Room: W: 19 x 16 x 8.5
The sitting area is at 16 and the PJ will be hung at 15. I can't move the setting area because there is a beam behind it but otherwise the area behind is open.
We will use the PJ to watch HD stuff from Comcast, Blu-ray movies and stuff downloaded from Web -- all via HDMI.
Is Optoma HD20 good option for this size room?
Is there a online tool to assist in where to put the PJ?
Does the screen material mater if you want a clean 1080p image on the screen?
What is the maximum size screen I can use?
any tips?
any tips?
