AVS › AVS Forum › Audio › CD Players & Dedicated Music Transports › Sony XA5400-ES
Sony XA5400-ES - Page 12
post #331 of 354
Originally Posted by dbphd View Post
The JC-2 is so neutral it seems to approach the ideal of a straight wire with gain. It replaced a Cary Cinema 11a, no sonic slouch, and seems to have lifted a vail to move me just a bit closer to the music. Both the 5400ES and 105 are capable of excellent sound with CDs or SACDs via analog output through the JC-2, even though their sound is slightly different. I intend to keep both, but if I had to choose just one it would be the 105, because it plays A/V Blu-rays as well as CDs and SACDs, and functions as a processor for speaker management and so forth. Multichannel music on DTS HD MA and Dolby True HD Blu-ray discs can be an amazing experience. I especially enjoy opera on Blu-ray.
db
yeah, I have an extensive CD, SACD, DVD-A, HDCD collection. Also significant size DVD and BluRay collection. Hence the purpose for aquiring the BDP-05. But I like having two players to experiment with, and as a way of "balancing" usage. I will probably use the SCD-XA5400ES for analog CD's and 2ch SACD moreso (and occasionally multi-channel SACD's via-HDMI). The Oppo BDP-05 for everything else, but mostly DVD's, BluRays, analog 2ch and multi-channel audio (also some mutli-channel via-HDMI, w/Audyssey).
post #332 of 354
I don't know what the rest of your system is like, but in a very revealing system the 5400ES doesn't come close to the BDP-95 or 105.
I sold my 5400ES and my Ayre C5xe because I just wasn't using them any more.
The 5400ES is a lot better than a lot of other players, but the SABRE DAC chips in the 95 and 105 are state-of-the-art.
They sound better than most players costing up to $8000.
post #333 of 354
I forgot to mention that the Oppo 105 also provides the DAC for my Mac Mini through its asynchronous USB port. Furthermore, I like the way the Oppo displays volume level on the screen when I'm using it for HT.
db
post #334 of 354
interesting, good to know. Guess I will have to hear for myself once I get things set-up and burned-in. Then do some extensive listening.
I'm using, both, the BDP-105 and SCD-XA5400ES, players. Marantz AV8801 processor, Parasound Halo A51 amp, Monitor Audio GS-Gold Series speakers (GS-60 fronts, GS-LCR center, GS-FX rears), and JL Audio F110 subwoofer, in a 5.1 configuration.
post #335 of 354
I alos traded the Sony for the OPPO especially with computer audio :)
post #336 of 354
yeah, the Oppo BDP-105 definitely has it's advantages, the number of features stands out (high performance video + multiple audio formats + discrete DAC).
On the other hand the Sony SVCD-XA5400ES implements a type of up-sampling for CD's.
post #337 of 354
Originally Posted by WestCoastD View Postyeah, the Oppo BDP-105 definitely has it's advantages, the number of features stands out (high performance video + multiple audio formats + discrete DAC).
What up sampling!
post #338 of 354
Originally Posted by wse View Post
What up sampling!
from what I understand the SCD-XA5400ES oversamples 16-bit 44.1kHz CD to "DSD-like" 2.8Msps 1-bit. CD's sound almost as good as SACD.
From Stereophile, Music In The Round, May 29, 2009 (quote):
"Sony's Technical Background paper spends a lot of words on SACD processing but says little about the player's CD processing, except to describe an 8x-oversampling filter and a noise shaper that result in a 2.8224MHz signal-sampling frequency—the same as that of DSD. "In this way, the SA-DAC presents both CD and SACD signals to the final converter stage in the identical 1-bit/64fs form." The explanation, presumably translated from Japanese, is not entirely clear, but if Sony is implying that CDs played on the SCD-XA5400ES should sound pretty close to SACDs, I think they have a good case."
http://www.stereophile.com/content/music-round-36-page-2
Edited by WestCoastD - 12/11/13 at 9:12am
post #339 of 354
from what I understand the SCD-XA5400ES oversamples 16-bit 44.1kHz CD to "DSD-like" 2.8Msps 1-bit. CD's sound almost as good as SACD. From Stereophile, Music In The Round, May 29, 2009 (quote):
Most interesting since Kal thinks the OPPO BDP-105 sounds better!
"Sony's Technical Background paper" where did you find that? Is this what you are referring to?
http://www.hifishock.org/galleries/Documents/Sony_ES_Sacd_Player_SCD-XA9000ES_Technology.pdf
Edited by wse - 12/11/13 at 10:21am
post #340 of 354
But note that the 500 Recommended Components in the October 2013 issue of Stereophile lists the 5400ES as A+ and the 105 as A.
db
post #341 of 354
But note that the 500 Recommended Components in the October 2013 issue of Stereophile lists the 5400ES as A+ and the 105 as A. db
Yes, but really if you do any computer audio the Sony is out! Same with Blu Ray concerts, or Blu Ray music from 2L or others so I will stick to the OPPO BDP105:D
post #342 of 354
What up sampling!
This might sound like heresy, but I find the SCD-XA5400ES better for CD than even its SACD playback. Its redbook CD sound quality is almost magical, turning many poor, modern masterings into something listenable. The CDs still don't sound quite as good as the SACDs, but for their limited resolution the CDs show greater improvement on the Sony than the differences it shows on SACDs from other players.
post #343 of 354
thanks, this is exactly what I was hoping for, a solid (dedicated) Redbook CD player, such that I can "split" duties between two players (BDP-105 & SCD-XA5400ES).
I owned a few premium Denon players a few years back (DVD-3930CI, DVD-3800BDCI), both feature AL24 (up-sampling) and they really performed exceptionally well playing CD's. However both exhibit known issues/failures (premature laser failures, etc.,...). Sony players, in my experience, have mostly been very resilient. I'm looking, mostly, for a dedicated player to last a while, I have a large Redbook CD collection.
post #344 of 354
I'm very familiar with those Denon players' sound quality, I had both of them at one time for regular listening. This Sony beats them on CD for the analog stereo outputs. It certainly has a smoother sound with more emphasis on the mid-range, though it is no slouch when it comes to revealing sonic clarity.
post #345 of 354
Since I rip all my CDs to my Mac Book Pro 13 inch retina display with 1TB SSD and use Audirvana that is not worth to me! I only use the SACD for multichannel SACDS and Blu Ray Audio biggrin.gif
post #346 of 354
Why would your comments be heresy on a Sony XA-5400ES thread? eek.gif As a matter of fact, I agree with you. I like the sound of the 5400ES better than the Oppo although the Oppo is the swish army knife of audio. I find, however, in my system, the Sony sounds better to my ears.
post #347 of 354
I primarily got it for the SACD features but was shocked at how good the XA5400ES sounded for CD. While I have a very large SACD collection by most standards, my CD collection dwarfs it in sheer size. I was thinking of buying an alternate player for CD after I got the XA5400ES for SACD, but in the end it saved me from buying two separate players. The only DAC I've heard that was clearly superior to the Sony on CD was the Benchmark DAC2. I didn't really sample the players priced above $2000 very much.
post #348 of 354
confused.gif http://matrixhifi.com/contenedor_dac1.htm
post #349 of 354
post #350 of 354
The future of Audio for Sony
quite a concept there..............
"Playback of DSD and the full range of Hi-Res file formats, Analog FIR filters, 1TB hard drive for local music playback and storage, DSD re-mastering engine converts all signals to DSD signals, built-in Wi-Fi for app control and music transfer"
Edited by WestCoastD - 12/15/13 at 6:35pm
post #351 of 354
Yes very nice but for half the price I get a Mac Mini with 1TB hard drive plus Audirvana and a lot better interface smile.gifbiggrin.gif
post #352 of 354
Very sad you can't use the DAC!
post #353 of 354
Yep.
I guess the unique features here, to me, are the DSD Masterine Engine + the 2ch analog (XLR)
post #354 of 354
I recently replaced my Cary Cinema 11a processor with a Parasound JC-2 analog preamp and have been using the balanced connection from my XA5400ES to the JC-2. The sound is substantially improved over that with the Cary, but a discussion at Audiogon about impedances leads me to ask if it might be better to use single ended rather than balanced. I've had the Sony for years and have used SE, XLR, and HDMI connections, but not with the JC-2. The SE input impedance of the JC-2 is 30 kOhms; the XLR is 30 kOhms per leg. Any opinions re SE v XLR? Are both simultaneously active on the XA5400ES? If so, I could connect both and switch between the two.
db
